20 Most Recent
Frigidaire 50 Pint Capacity Dehumidifier Questions & Answers
Clean frigidaire dehumidifier cooling coil
Hello Friend, thank you for your post!
I see that you would like to know how to clean the coils on your Frigidaire dehumidifier and that it is no longer collecting water. The best way to clean the coils is by using a brush attachment from your vacuum. Typically there are one or two reasons why your dehumidifier is not collecting water. Either the setting might be set too high or not enough moisture in the room. I suggest changing the set point to a lower setting. As humidity drops in the room the amount of water will decrease and very little water may be generated even when in continuous mode. If these basic troubleshooting tips prove ineffective, then your dehumidifier may possibly have system issues. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best - Z
Bucket full showing
Hello Friend, thank you for allowing me to assist you!
Once the "BUCKET FULL" illuminate on your Frigidaire dehumidifier, soon after your appliance will shut down. Then you may remove the bucket by pressing the sides gently to unclip it and empty the collected water. After you reinstall the bucket, the float switch will reset. Hope this helps! - Z
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..
