20 Most Recent
Zanussi 24 in. ZSF6160 Free-standing Dishwasher Questions & Answers
My dishwasher leaks water when
Hello & Welcome to FixYa
The problem is with the water not draining properly or is overflowing. If the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, to do this you'll have to take the front bottom panel out and then clean it completely. If you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Got a zanussi dishwasher zsf6160, lights working
if you can here the drain pump run at the start the fault is with the water valve or blockage in the side tank on the lh side. if you dont here the drain pump it possibly the heater thats down to earth. the electronics can detact it and not start the prog if heater faulty.
Water not heating
probably not, believe it or not. If they actually designed a trace to fail under load, then they could not predict when it may happen. Yes, things get more load-some over long use and demand more current, but the pcb trace was probably not intentionally too small. Let's say it was designed too small. So at first startup it carries 9.5 Amps. The next factory unit draws 9.8 amps. the next unit, wait a minute, draws 10 amps and blew the trace before it got shipped. I think this under-design was a simple oversight, but one that should have demanded a product recall from Zanussi that would send a tech to every unit to install a pcb with a beefier trace. Email Zanussi and complain! Just curious...can you measure how wide is this pcb trace? It should be about 1/4 inch wide.
Zanussi ZSF6160 Water not heating
Mantona, you're on the right track. Your heater terminals are large, insulated and poke through the tub facing downward. To test this, remove one of the wires connected to the terminal, then check OHMS. If this is what you did, you don't have to do that again. Elements rarely fail, the problem most likely resides in the hi-limit thermostat.
You know where the element is, now follow one of the wires back toward the control panel. One of the element wires will pass through the thermostat (in series) before going to the control. The thermostat is mounted tightly to the bottom of the tub, touching it to monitor temperature. When you find it, remove one of the wires (there are 2) and check OHMS. You should read ~1 Ohm, if you read infinity, you found the problem. (You can verify your finding by removing both wires from it and connect them together. Then run a wash load to check the heater. Don't leave it in this condition! The thermostat is a safety device and should not be permanently bypassed!
If your test of the t'stat proves that it's OK, you'll have to test it with power on and running. I can walk you through this if needed. Let us know how it turns out.
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat;
https://behealthyideas.com/
<ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM •
Zanussi...
Answered
on Jan 18, 2023
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM •
Zanussi...
Answered
on Nov 30, 2021
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
9/18/2021 8:05:04 AM •
Zanussi...
Answered
on Sep 18, 2021
