20 Most Recent
Invacare Pronto M91 with SureStep Questions & Answers
Why does my chair slow down, and then stop? It's not the fuses or the batteries.
hi again if u got youre batteries tested with a battery load tester 100 amp similar to one in photo ok then u have to get youre control box checked and youre joy stick to find out the problem ...good luck.... hi get youre batteries tested with a ( battery load tester )the lights on youre scooter r not a true reading on the condition of youre batteries..good luck
How to recharge batteries.
Hello,i would check with the manufacturer for the charger.Remember,if you do not follow guidelines set out.It could affect any guarantee.I am disabled myself & the batteries are not cheap,even though VAT is not charged for us.When you provide proof of Disability.I hope this helped.
Reset of dash lights RE. Potentiometer -
hi John, the tiller display you got on that scooter , if all of the lights are coming on even when the battery power is low sadly is a faulty component, they are cheap to repair and is now a common problem because they quite old ..
Regards
Rob
Invacare Leo back wheels seizing up and also hard to push without locking in freewheel mode
hi Helen, firstly the scooter will lock up after a couple of metres , that is by design to stop you rolling down a hill etc ..
Now if the scooter is hard to push even in freewheel, means the brake has either decided to seize (lack of use , been in storage ) or has become damage. The mechanism for releasing the brake has become damaged . brake removal recommended then try to push the scooter , if it 's okay then its the brake if not , it could be the coupling between the motor and gearbox has failed or the gearbox itself has a issue,.
Regards
Rob
Are both lights supposed to be green i have 1 red 1 green on my battery for my invacare scooter
Mine is an Invacare M51 Pronto Surestep with an onboard Winsunny battery charger. My charging lights are solid red and green/ yellow. Depending on if it is charging or not. What kind of charger do you have?
I have to replace my charger because it is not working. My green light is staying green while charging even though my joystick is showing my batteries are depleting and I just got new batteries. sigh.
