20 Most Recent Zanussi ZWF1450W Front Load Washer Questions & Answers
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Zanussi ZWF1450W... | Answered on Jan 30, 2011
Let us know if this is the correct guide or not, using the Comment menu.
http://kitchen.manualsonline.com/manuals/mfg/electrolux/ls14.html
Zanussi Washing... | Answered on Dec 07, 2020
The start button (switch) or cycle timer could be defective.
Zanussi Washing... | Answered on Nov 10, 2020
Before it will start the brain needs to know the door is closed and locked. The door catch is connected to the brain - perhaps they are no longer communicating...
Zanussi Washing... | Answered on Jun 24, 2020
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Zanussi Washing... | Answered on May 25, 2020
https://www.zanussi.co.uk/support/support-articles/laundry/washing-machines/washing-machine-does-not-drain-displays-error-message-e20-e21-or-c2-emits-2-beeps-2-flashes/
Zanussi Washing... | Answered on May 23, 2020
Is this the first time it's happened? Normally, a washing machine door won't open if a) not enough time has passed since the end of the cycle to the door unlocking itself, in which case you'd wait till for the unlocking click. You could also just switch the machine off, then switch off the power to it, then wait for 30 seconds before switching on again. OR b) the level of water inside the drum is too high. Have you checked that it has drained properly? Or if there is any blockage in the filter (usually behind a square panel bottom front of the machine), which may need cleaning out. Or a blockage in the drainage hose (at the back and connected to your water to drain pipe). Also, on some models, where you'd access the filter (and clear the fluff out from), there is often an emergency door opening lever beside it which you have to put down. But this should be a last resort. If you do have to use it, you have to reset the machine after by switching off power, waiting for 30 seconds then switch power back on again. Hope this helps and one of them works.
Zanussi Washing... | Answered on Mar 02, 2020
try a new fuse in the plug 13amp eric
Zanussi Washing... | Answered on Jan 13, 2020
broken circuit in printed circuit board
Zanussi Washing... | Answered on Sep 16, 2019
Hi.
This sounds like doorlock issue.
You can access it from the door panel.
Panel has 4-6 screws.
From there you can check it with a multimeter (ohm setting).
It could also be as simple as bent door hatch, door lock not engaging with doorlock.
Zanussi Washing... | Answered on Sep 10, 2019
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
Zanussi Washing... | Answered on Jun 29, 2019
E20 means problem with drain water phase
Only two things need to be checked:
- Drain pump could be clogged or no power supply (the last means
faulty drain pump, faulty electronic or wiring between drain pump
and electronic.
- Your home drainage system (in the wall) is clogged (This is very
easy to check visually, disconnect the drain hose from your
siphon and put water in some container or in washbasin.)
Dado
Zanussi Washing... | Answered on Jun 15, 2019
Zanussi ZWF1450W Front Load Washer Logo
13 questions posted
Top Zanussi Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Nicola Conroy
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
washing machine selected spin drain
  • Washing Machines
