20 Most Recent Zanussi ZWF1650W Front Load Washer Questions & Answers
2answers
My washing sent in control panel alarm is ( EHO)
C\nt find a fault code EH0. EH1 EH2 AND EH3 all relate to power supply problems voltage to high or low . the electronics dont like a dirty supply spikes and fluctuations upset them. they dont always work from a small generator supply.
9/14/2018 3:49:57 PM • Zanussi ZWF1650W... • Answered on Sep 14, 2018
0answers
2answers
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
6/26/2012 6:09:25 PM • Zanussi ZWF1650W... • Answered on Jun 26, 2012
2answers
My Zanussi zwf1650w comes up
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
7/4/2011 1:01:47 PM • Zanussi ZWF1650W... • Answered on Jul 04, 2011
I have a Zanussi 1600
This is worth a try-
It is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever and possible some good!
You could consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
5/1/2011 4:46:39 PM • Zanussi ZWF1650W... • Answered on May 01, 2011
KEEPS FLASHING Z20 CODE
I take it you mean E20 if so this is related to a blockage,have you checked the filter and pump for blockages.
Hope this helps.
8/9/2010 9:04:31 AM • Zanussi ZWF1650W... • Answered on Aug 09, 2010
My zanussi timeline 1600 washing machine has
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Please rate my solution.
Thankyou.
1/16/2010 4:32:41 PM • Zanussi ZWF1650W... • Answered on Jan 16, 2010
2answers
No elecrical current.
She's a fried!
Either a capacitor on the control board has popped, or the power cable somewhere inside the unit has worked loose and the circuit is open.
3/26/2009 9:32:28 PM • Zanussi ZWF1650W... • Answered on Mar 26, 2009
Zanussi Lindo 300..keeps adding water to finishing spin cycle
If your Zanussi Lindo 300 washing machine keeps adding water to the finishing spin cycle, there may be a few possible causes. Here are some steps you can try to diagnose and fix the problem:
  1. Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
  2. Check the Water Inlet Valve: The water inlet valve may be faulty, which can cause the washer to continue adding water. You can try cleaning the valve or replacing it if it is faulty.
  3. Check the Pressure Switch: The pressure switch controls the water level in the washer. If it is faulty, it can cause the washer to continue adding water. Try cleaning the switch or replacing it if it is faulty.
  4. Check the Control Board: The control board is the brain of the washer and controls all the functions. If it is faulty, it can cause the washer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
  5. Check the Door Lock: The door lock may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try cleaning the lock or replacing it if it is faulty.
  6. Check the Motor: The motor may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try resetting the motor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer thoroughly and ensure that it is working correctly and safely.
3/9/2023 2:27:42 PM • Zanussi Washing... • Answered on Mar 09, 2023
ZWH 7149 P won't agitate.
Either one of these. Control board has failed. Control knob has failed. Motor has failed. Motor controller has failed. If you can hear the motor turning, the coupler has failed. You need a service call to get correct diagnostics and warranty on the repair. The video _may_ help? https://www.google.com/search?q=Zanussi+ZWH+7149+drum+not+turning ..
10/29/2022 6:08:43 PM • Zanussi Washing... • Answered on Oct 29, 2022
Zanussi drains after pre wash but does not drain next cycle
This is a logic board issue. Call for service for the correct diagnosis and warranty on the new part.
10/13/2022 3:36:19 PM • Zanussi Washing... • Answered on Oct 13, 2022
Zanussi Aquacycle 1100 XC - when trying to start the machine the door clicks 3 times and then I get a error / beeping sound.
Hi, Please clean out the interior of your machines and clean any filters as necessary, then attempt to run again. If this continues, please call Zanussi at 03445 610 645 to help overcome the issue. Thank you.
9/30/2022 7:51:29 PM • Zanussi Washing... • Answered on Sep 30, 2022
Zanussi FJS1197W washing machine periodically wont drain at end of wash phase
It is very unusual for a front loader, it does have both a recirculation pump and a drain pump! I don't see any diverter valves. Exploded parts diagram. https://www.ransomspares.co.uk/parts/brands/zanussi/washing-machines/fjs1197w%20%2891478851400%29/ ..
7/24/2022 10:30:56 PM • Zanussi Washing... • Answered on Jul 24, 2022
Zanussi Lindo 300 tumble dryer buttons not responding!
The machine has a Diagnostics Mode if you can get to it. It also has a Reset https://www.google.com/search?q=Zanussi+lindo+300+reset ...
6/18/2022 3:55:34 PM • Zanussi Washing... • Answered on Jun 18, 2022
How to remove control panel on zanussi ZCM700X
video in the link. Manual if you need it, but no service manual. https://www.google.com/search?q=remove+control+panel+on+zanussi+ZCM700X ..
5/26/2022 4:12:48 PM • Zanussi Washing... • Answered on May 26, 2022
Zanussi ZWF1650W Front Load Washer Logo
26 questions posted
Top Zanussi Washing Machines Experts
W.L.
Marvin
Marvin
sheakhly
Level 1 Expert
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
washing sent in control panel alarm eho
  • Washing Machines
