20 Most Recent Invacare Leo 4 Wheel Mobility Scooter Silver Questions & Answers
Sorry, that would be NO. Know how you feel.
Invacare Leo 4... | Answered on Feb 07, 2018
It could be the wig-wag at fault and need replacing. A loose or bad connection on batteries or drive system. Speed pot worn.
Are the batteries old? May need load testing.
Invacare Leo 4... | Answered on Apr 14, 2016
how old are the batteries? I'd look for batteries on Ebay , but check connections to the battery and the charger first! Dirty or corroded batteries may prevent the charger from working properly. Is the charger good? Is the outlet it is plugged into alive?
Invacare Health... | Answered on Jun 29, 2020
https://www.youtube.com/watch?v=i2gFmNrgk2M
Invacare Health... | Answered on Mar 13, 2020
Unlocking Power Wheelchair Joysticks - Statewide Mobility
https://www.statewidemobility.com/.../unlocking-power-wheelchair-joysticks/
5 Jul 2014 ... Unlocking power wheelchair joysticks is essential to a power wheelchair owner. ... Many of you who use power wheelchairs do not fully know the hidden ... joystick, which is commonly found on Invacare power wheelchairs.
Invacare Health... | Answered on Jan 31, 2020
hi, sounds like a issue with the tiller circuit board or are the batteries fully charged ? i seen this before on low voltage batteries. the tiller board etc need a minimum voltage to work around the 20+ voltage, any lower will cause the effect you describe..
Invacare Health... | Answered on Jan 28, 2020
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
Invacare Health... | Answered on Jan 14, 2020
sounds like a loose/broken wire if it takes a jarring to cause the problem. a careful inspection of the wires and connectors might be helpful.
Invacare Health... | Answered on Dec 04, 2019
it indicates that the SB900 battery has been placed in the charger incorrectly. The battery is positioned "backwards." That is, the label is still facing up but the orientation has been reversed for the positive and negative ends.
Invacare Health... | Answered on Nov 28, 2019
If the brake is applied by electromagnetism, power must be supplied to the coils by either manual or electronic switching.
I suggest you investigate the circuit to discover how the power should be supplied to the brake coils and then it will be easier to trace the fault.
As a matter of not unrelated interest, it is fairly usual to arrange the wiring/switching so when power isn't being supplied to a low voltage DC motor the motor terminals are shorted. When being pushed the motor becomes a generator and the input becomes and output and so shorting that output makes the motor self-braking to some extent - this is why car windscreen wipers are able to stop almost instantly...
Invacare Health... | Answered on Nov 27, 2019
If by the "ball" you're referring to the type of flow gauge that works by a stream of gas pushing up a small plastic ball in a clear tube or drilled piece of clear plastic, then the ball is either stuck somehow (moisture in its tube might do that by causing some friction), or it's showing there's no flow of oxygen enriched air, meaning the concentrator itself is not working. Can you feel some air flow if you hold the outlet towards the skin on your cheek?
Invacare Health... | Answered on Sep 12, 2019
Sounds like your battery is bad. Replace it.
Invacare Health... | Answered on Jul 01, 2019
Invacare Leo 4 Wheel Mobility Scooter Silver Logo
2 questions posted
Top Invacare Health & Beauty Experts
Rob Hill
Rob Hill
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Invacare Health & Beauty
Most Popular Question
fit shock absorbers leo invalidate
  • Health & Beauty
