20 Most Recent AOpen DUW1608/ARR (914ID37002) DVD±RW Dual Layer Burner Questions & Answers
Hi there, you should probably try to open the burner manually, to do so, usualy there is a small hole on the from that you should push with a pin and this will open the dvd. Sometimes the dvd can get stuck if it is not centered perfectly. Thanks.
AOpen... • Answered on Mar 09, 2011
Check which flate cable do you have for its connection. AOpen recommendation is for 80-wire ATA-66/100 cable. In case this is not the cable you have, you should replace it. (The ATA/66/100 IDE cable is made from 80-conductor wire with 40 pin connectors, providing the superior ground spacing required by the ATA/66/100 specs, and allowing the full 100 Mbps burst transfer rate). Another AOpen recommendation is to configur the unit as a "Master" and not as a slave. Good luck
AOpen... • Answered on May 05, 2006
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
AOpen Computers... • Answered on Jan 25, 2018
CHECK THE ELECTRICS IS PSU WORKING ?
AOpen Computers... • Answered on Jun 01, 2015
I am assuming that you are replacing or installing a new mobo. You need to read the manual to see if it has an option for speakers, most do. You need to look the details for the "front panel" where you connect wires for power, hard disk lights etc.
AOpen Computers... • Answered on Feb 24, 2015
You can go to the link below and enter the board name is a MX4GER and that will give you your manuals Download Center
AOpen Computers... • Answered on Feb 19, 2015
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#1
AOpen Computers... • Answered on Sep 01, 2014
If you open your motherboard, then you can see a lot of input and output ports behind the motherboard, where you connect VGA, mouse, keyboard etc wires at that place there is a 3.5mm jack which may be green in color, you can connect specker wire there A red mark is shownf0e57a9b-b042-492e-a159-ddede3ddc5aa.jpg
AOpen Computers... • Answered on Aug 15, 2014
if you are directly connected to the router via ethernet go through the ip gateway, open up a web browser usually d-links ip gateway are 192.168.1.1, you might have to look up you model. Also note you may have a default login and password, such as admin for password and admin for user. note you can also reset the password on the router by holding the reset button for 10 seconds. More questions heres a refrence guide http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%202750B/Manual/DSL_2750B_B1_Manual_v1_00_EN.pdf
AOpen Computers... • Answered on Aug 13, 2014
check out drive
AOpen Computers... • Answered on May 11, 2014
Computers & Internet Logo
2 questions posted
Top AOpen Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOpen Computers & Internet
Most Popular Question
burn
  • Computers & Internet
