20 Most Recent AOpen (DUW1608/ARR) (914ID37202) Burner Questions & Answers
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
AOpen... • Answered on Dec 30, 2010
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
AOpen Computers... • Answered on Jan 25, 2018
CHECK THE ELECTRICS IS PSU WORKING ?
AOpen Computers... • Answered on Jun 01, 2015
I am assuming that you are replacing or installing a new mobo. You need to read the manual to see if it has an option for speakers, most do. You need to look the details for the "front panel" where you connect wires for power, hard disk lights etc.
AOpen Computers... • Answered on Feb 24, 2015
You can go to the link below and enter the board name is a MX4GER and that will give you your manuals Download Center
AOpen Computers... • Answered on Feb 19, 2015
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#1
AOpen Computers... • Answered on Sep 01, 2014
If you open your motherboard, then you can see a lot of input and output ports behind the motherboard, where you connect VGA, mouse, keyboard etc wires at that place there is a 3.5mm jack which may be green in color, you can connect specker wire there A red mark is shownf0e57a9b-b042-492e-a159-ddede3ddc5aa.jpg
AOpen Computers... • Answered on Aug 15, 2014
if you are directly connected to the router via ethernet go through the ip gateway, open up a web browser usually d-links ip gateway are 192.168.1.1, you might have to look up you model. Also note you may have a default login and password, such as admin for password and admin for user. note you can also reset the password on the router by holding the reset button for 10 seconds. More questions heres a refrence guide http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%202750B/Manual/DSL_2750B_B1_Manual_v1_00_EN.pdf
AOpen Computers... • Answered on Aug 13, 2014
check out drive
AOpen Computers... • Answered on May 11, 2014
Computers & Internet Logo
Popular Tags
1 questions posted
Top AOpen Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOpen Computers & Internet
Most Popular Question
dvd drive starts stops light
  • Computers & Internet
