20 Most Recent AOpen DUW1608/ARR (914ID37204) Burner Questions & Answers
you will need "flash magic" software, a device to provide 12V power supply to device, one cable to transfer data,download the working firmware for you device and save it to your device.
AOpen... • Answered on Mar 01, 2011
Right click on my computer>properties>device manager>hardware and look for line saying cd/dvd drives and highlight your dvd burner. Right click it and click uninstal. Restart your pc and Windows will automatically re install it. See if this works, if not either needs a lazer clean disc or you need to replace it they are cheap these days.
AOpen... • Answered on Oct 20, 2008
it's a classic drive failure problem where the laser can no longer burn or read dvd's, and show rhr writer as a cdrw, but may still be able to read or write cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
AOpen... • Answered on Aug 11, 2007
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
AOpen Computers... • Answered on Jan 25, 2018
CHECK THE ELECTRICS IS PSU WORKING ?
AOpen Computers... • Answered on Jun 01, 2015
I am assuming that you are replacing or installing a new mobo. You need to read the manual to see if it has an option for speakers, most do. You need to look the details for the "front panel" where you connect wires for power, hard disk lights etc.
AOpen Computers... • Answered on Feb 24, 2015
You can go to the link below and enter the board name is a MX4GER and that will give you your manuals Download Center
AOpen Computers... • Answered on Feb 19, 2015
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#1
AOpen Computers... • Answered on Sep 01, 2014
If you open your motherboard, then you can see a lot of input and output ports behind the motherboard, where you connect VGA, mouse, keyboard etc wires at that place there is a 3.5mm jack which may be green in color, you can connect specker wire there A red mark is shownf0e57a9b-b042-492e-a159-ddede3ddc5aa.jpg
AOpen Computers... • Answered on Aug 15, 2014
if you are directly connected to the router via ethernet go through the ip gateway, open up a web browser usually d-links ip gateway are 192.168.1.1, you might have to look up you model. Also note you may have a default login and password, such as admin for password and admin for user. note you can also reset the password on the router by holding the reset button for 10 seconds. More questions heres a refrence guide http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%202750B/Manual/DSL_2750B_B1_Manual_v1_00_EN.pdf
AOpen Computers... • Answered on Aug 13, 2014
AOpen DUW1608/ARR (914ID37204) Burner Logo
3 questions posted
Top AOpen Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOpen Computers & Internet
Most Popular Question
aopen duw1608 arr problem
  • Computers & Internet
