20 Most Recent
Honeywell TH9421C1004 VisionPRO IAQ Total Home Comfort System Questions & Answers
Why is it showing error code 90?
Sounds like a all the bells and whistles thermostat, why did you chose that one?
090 Data interface is continuously busy.
A log of error codes can be viewed at the end of the installer setup after the system tests. Active errors will be shown first. The Error Log will log the last ten errors (active and inactive).
Pressing the reset button will clear all inactive errors from the
error log; active errors can not be cleared until the condition has been remedially busy
4/17/2016 4:41:37 PM •
Honeywell...
Answered
on Apr 17, 2016
Auto does not show in system
On Honeywell thermostats you have to program the thermostat on the setup mode to have the auto to be on the display. The setup instructions will walk up through it. If you do not have them, you can down load them to you computer.
7/21/2014 3:42:20 AM •
Honeywell...
Answered
on Jul 21, 2014
Touch screen stopped responding
Pull the thermostat face off the wall. Wait a few minutes, & gently line up the pins and place back on. Let display pull up. If that doesn't work, your thermostat is probably under warranty...Replace.
12/13/2013 11:52:35 AM •
Honeywell...
Answered
on Dec 13, 2013
Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
6/22/2013 10:20:39 PM •
Honeywell...
Answered
on Jun 22, 2013
