20 Most Recent Apacer Memory APACER AUDIO STENO AV220 1GB USB FLASH DRIVE & MP3 PLAYER (AV2201GB) Drive Questions & Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ok tu peut essayer de la formater
Suivre les étapes suivant:
cliquer le : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
essayer de la formater en fat 32 et fat nfts
Merci
uttam
Apacer Memory... | Answered on Jan 13, 2010
Plug it in and see if it shows up in my computer if not then install the drivers off the CD that came with it
Apacer Memory... | Answered on Dec 02, 2009
your gonna have to reinstall all your stuff as I always tell peeps if you need to reformat or clean up your files and you got alot of data you should always have a copy or backup files on your puter. Sorry
Apacer Memory... | Answered on Apr 12, 2006
o.k. have you tried the same pen drive on another computer?
if no, please try this and see if you get the same result?
if yes, unfortunately you may have to reformat your pen drive.
your data on the drive may also be lost.
sorry sometimes these things happen.
Apacer Memory... | Answered on Mar 26, 2010
Hello there,
You will notice a small tab in your memory card that can be adjusted up or down. To unprotect it, just adjust it up or vice versa.
Hope this helps.
Apacer Memory... | Answered on Oct 27, 2009
Locate the battery, remove the battery, replace the battery.
Computers &... | Answered 15 hours ago
Yes they are. Printers are one of the most common types of output devices but they can also be considered input devices because of the multi-function printers that include scanners and copiers.
Computers &... | Answered 16 hours ago
On what we all wonder. ............
Can you logon to your computer in normal mode or only in Safe mode?
This would be the best way to run Chkdsk:
1. Disable any security software before attempting to upgrade or do a clean install.
2. Make sure your computer is updated (devices and applications)
3. Disconnect any external devices before installing.
4. Check your hard disk for any errors:
Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: chkdsk /r /f
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them.
There are other fleshed-out ways to run CHKDSK in the following article:
Quick Fix: CHKDSK Cannot Open Volume for Direct Access Error
Computers &... | Answered 17 hours ago
1. Update drivers, BIOS or Windows of your PC.
2. Run SFC
3. Run DISM
It's tricky to pin down a panacea for this problem since the causes of it vary. You can check out this article to read a more comprehensive and detailed list of solutions:
Fix: Thread Stuck in Device Driver Error [16 Solutions]
Computers &... | Answered 18 hours ago
Open movie maker. Open a new project. Now import the two video clips. Place them accordingly... in the storyboard (or timeline) And export it to a new movie, in to your favourite format.
Computers &... | Answered 24 hours ago
it either doesnt work with win 10 or you need to contact them to get a new key
Computers &... | Answered Yesterday
YOU GET A DEGREE FOR THAT SINCE IT CAN NOT BE DONE
You can refer to this article, which presents several fleshed-out solutions.
Quick Fix 'This Device Is Currently in Use' & Safely Ejecting Tips
Computers & Internet Logo
6 questions posted
Top Apacer Memory Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Apacer Memory Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apacer Memory Computers & Internet
Most Popular Question
j ai le mp3 tout le temps allume
  • Computers & Internet
