20 Most Recent General Electric 24,000-BTU EnerStar Window Air Conditioner AEW24DQ Questions & Answers
Why won't the heater of ge zoneline 2100 stay on
Hi, If the heater goes off right away when you start it, please check the corresponding fuse within your fusebox. Also, checking for any warn wires would be good as well. I would also test other outlets verify that it's not your current power source that's the issue. Thank you.
11/3/2022 12:49:49 AM • GE Heating &... • Answered on Nov 03, 2022
2answers
Why will my GE Zoneline 2100 work on high cool and high heat settings, but on low cool and low heat the fan won't run.
I don’t believe the remote tstat accepts those functions to change the fan speed versus using the on board controls. Try to change the fan speed while using the on board controls and when you have that setup then go back and change it to remote tstat setting.
8/21/2022 7:49:26 AM • GE Heating &... • Answered on Aug 21, 2022
What does a code E4 mean on my GE window air unit?
https://www.reviewhomewarranties.com/home-maintenance/hvac/fixing-e4-error-on-air-conditioner/
7/30/2022 9:24:11 PM • GE Heating &... • Answered on Jul 30, 2022
GE air conditioner jumps to 86 on the display
bad temp sensor
5/19/2022 3:57:38 AM • GE Heating &... • Answered on May 19, 2022
I have a GE refrigerator model number GTS18GTHSRWW it has stopped cooling and the freezer has stopped also I opened the panel in the back and found three green and yellow wires not connected.
Green and Yellow are earths, so those aren't the issue. You need a service call. The most likely reason is that you have a refrigerant gas leak.
1/12/2022 4:33:00 AM • GE Heating &... • Answered on Jan 12, 2022
GE profile microwave convection does not reach temperature
Needs a new thermostat or heat sensor. Take it in for professional service.
12/31/2021 3:37:43 AM • GE Heating &... • Answered on Dec 31, 2021
I need de remote code for split system air conditioner GE model AS1AC18MBO01
so order one do a search for one
11/5/2021 6:49:56 PM • GE Heating &... • Answered on Nov 05, 2021
GE portable AC will automatically change the settings and temp on its own
I would change the codes from remote to AC control. Someone else nearby may have one and getting the same issues when you adjust yours.
10/28/2021 7:25:03 AM • GE Heating &... • Answered on Oct 28, 2021
I have ac Intertherm outdoor unit,the name tag is gone,I can not figure out the model number
Both compressor and fan motor should have capacitor ratings on data plates.
9/11/2021 8:22:31 PM • GE Heating &... • Answered on Sep 11, 2021
GE ROOM AHC24DZH1 Room Air Conditioner will not stay on?
Take it apart again and reassemble. Ensure all connections are good and wires not pinched.
9/3/2021 3:59:29 PM • GE Heating &... • Answered on Sep 03, 2021
GE window ac unit smells like vinegar
you better call a repair service locally it is leaking the coolant probably
5/10/2021 7:26:30 AM • GE Heating &... • Answered on May 10, 2021
EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
4/29/2021 9:31:46 AM • GE Heating &... • Answered on Apr 29, 2021
Why does ptac compressor short cycle in heat mode?
It is usually two things; a faulty thermostat or overheating.
12/16/2020 11:52:47 PM • GE Heating &... • Answered on Dec 16, 2020
My GE window AC Model#AEL06LXQ1 Serial#AM311149P
The E8 code indicates that the unit is in an overload situation. This can happen when the air is too hot/humid. Make sure that the air around the unit is below 90 degrees F. It can also happen if there is a buildup of dirt or dust on the filter, at the air intakes and the exhaust ports. You should be able to check the filter for dirt and dust yourself. If you can, try to check for any insect nests, leaves or grass in the window well. You probably need someone else to help you clean the rest of the unit. I hope this helps. Cindy Wells
12/2/2020 5:50:20 PM • GE Heating &... • Answered on Dec 02, 2020
General Electric 24,000-BTU EnerStar Window Air Conditioner AEW24DQ Logo
1 questions posted
Top GE Heating & Cooling Experts
ray gallant
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • GE Heating & Cooling
Most Popular Question
ge air conditioner jumps 86 display
  • Heating & Cooling
