20 Most Recent Altec Lansing iM3 Computer Speakers Questions & Answers
Altec Lansing inMotion Audio Docks Mini Speakers eBay Search eBay for low priced identical model if possible and purchase it to replace any broken parts.
Altec Lansing... • Answered on Feb 20, 2018
The power adapter could be bad BUT also the jack it plugs into may be bad. It will have a switch to disconnect the battery when adapter is plugged in.
You need to get a voltmeter and check the output of the adapter. OFTEN the cable beaks where it flexes. Sometimes the cable can be spliced, but DO be careful to not reverse the wires.
Altec Lansing... • Answered on Dec 23, 2009
I have read the user manual for this product and it seemes to me you may have a defective battery.
Altec Lansing... • Answered on Mar 19, 2008
GET IT REPAIRED IT HAS A TECHINICAL FAULT
Altec Lansing... • Answered on Nov 25, 2007
have you checked the voltage requirement of the speakers?possibly, the voltage requirement of your speakers isn't adequately supplied by your batteries.if this is the case,please purchase the necessary batteries that would suffice the needs of your speakers.
Altec Lansing... • Answered on Sep 27, 2007
Get a new battery.. that one is shot.. it wont take a charge thats the reason bud
Altec Lansing... • Answered on Aug 11, 2007
Could be somthing wrong with the speaker.. Get a hair dryer and blow the air into the speaker its self. ods are you have gotten water or some liquid into the speaker its self and messed it up ... I would advise getting a new speaker for it or somthing =)
Lol, sounds like that iPod sucked the power out of your house. Just kidding. If it is plugged into a wall outlet, make sure that the conections are not bent or warped in any way (remeber this stuff is very fragile so look for the smallest stuff). If it is plugged into one of those multi outlet devils, make sure that is not too clogged up. For those I always use the Male Bathroom Ediquate rule, never stand (nor plug) next to a guy in another urinal.
Altec Lansing... • Answered on Jun 18, 2007
They are disposable items, very poorly designed and bad quality. I had a great set early 90's, they failed so I bought another set around 2010. The hissed even when turned off so I donated them!. I bought a pair of Bowers and Wilkins MM1. A whole different ball game in quality, sound and a lifetime warranty. The problem is getting into them as they have secret hidden plastic catches. Go around the seam in the body with a spudger to look for the catches.
Altec Lansing... • Answered on May 02, 2021
A constant low hum is a sign of a power supply issue. You need to check the capacitors that filter the ripple current and you need to check the diodes that convert ac to dc
Altec Lansing... • Answered on Feb 26, 2021
Could be a failing power supply
Altec Lansing... • Answered on Oct 29, 2020
Altec Lansing iM3 Computer Speakers Logo
18 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
altec lansing im3 no longer works ac
  • Audio Players & Recorders
