20 Most Recent Pride Electric Wheelchair, Scooter, Power Chair, Used, Jet 3 Ultra Questions & Answers
hi,
3 The left motor has a short circuit to another connection. Contact your authorized Pride Provider.
Regards
Rob..
Pride Electric... | Answered on Aug 29, 2015
hi, there can be a number of reasons for this, from a controller fault to a weak pair of batteries to a brake that is breaking down..
Please contact me so i can advise further...
Regards
Rob
www.gewizrepairs.co.uk
Pride Electric... | Answered on Jul 10, 2015
what's the problem?
Pride Electric... | Answered on Jul 21, 2014
The one thing that wouldn't cause the noise is the batteries.
If it is an electrical noise, it will be the speed controller as they go slower in reverse than in forward.
If it is mechanical, it might be the brake or the motor drive. Take it to your local dealer for correct diagnosis and repair IF needed.
Pride Health &... | Answered on May 20, 2020
https://www.youtube.com/watch?v=J2gB3FGUJXc
A lot of times when the mobility scooter cuts off, the gauge on the battery drops to zero. ... The most common reason for a fast-depleting battery is age. As batteries age, they store less charge and are less efficient. So not only do they lose their charge faster, they have little of it to begin with.
https://activeseniorsclub.co.uk/mobility-scooter-keeps-cutting-out/
Pride Health &... | Answered on Apr 17, 2020
8 flashes means there is a power module issue. Check the connections at the battery and power module. If ok, check the battery, it may need replacing.
Pride Health &... | Answered on Jan 28, 2020
ow To Fix Your Scooter That Won't Turn On Or Charge - YouTube
https://www.youtube.com/watch?v=rgK2l6cMCc4
17 Mar 2017 ... GoGo Or Go Go power chair repair. How to replace the batteries in the sealed battery box on your power chair scooter. Battery: UB12180.
Pride Health &... | Answered on Jan 24, 2020
One light flashing means: The batteries need charging or there is a bad connection to the batteries. Check the connections to the batteries. If the connections are good, try charging the batteries.
Pride Health &... | Answered on Dec 24, 2019
hi Peter at worse, ,sounds like a controller fault, are you uk based?
could be that the motor brushes are causing the fault.
If so i can repair them from £20.
regards
Rob
Pride Health &... | Answered on Dec 22, 2019
The flashing light is flashing a code that indicates an electrical problem. See your manual for the codes on pg 38.
Pride Health &... | Answered on Dec 14, 2019
well if you never tell anyone what it is no one can guess
sadly fixya can not fix it for you we do not have field tech or a service dept
Pride Health &... | Answered on Dec 13, 2019
Request a wiring diagram from Pride.
Pride Health &... | Answered on Nov 27, 2019
sorry there is no such thing however if you tell me the issue I can advise you ...
Pride Health &... | Answered on Nov 02, 2019
hi It's located at the rear of the scooter under the battery cover , there are some fuses located on the tiller stem, depending on what legend you have .
Regards
Rob
Pride Health &... | Answered on Oct 06, 2019
Pride Electric Wheelchair, Scooter, Power Chair, Used, Jet 3 Ultra Logo
3 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
working fine suddenly stopped off
  • Health & Beauty
