20 Most Recent Zanussi TD4212W Electric Dryer Questions & Answers
Hi, My Zanussi TD 4112 W
Could also be improper voltage going to unit or a half tripped breaker sending only 110v. Could be be a thermostat or thermal limiter. Could be timer or motor also. Many different possibilities
9/22/2017 3:23:48 PM • Zanussi TD4212W... • Answered on Sep 22, 2017
Electric dryer
Check lint filter and exhaust hose for clogs, clean and make sure it's clear.
10/11/2014 1:07:10 PM • Zanussi TD4212W... • Answered on Oct 11, 2014
Working but only cold air circulating
Most likely the heqater element has failed.
9/12/2013 9:50:09 PM • Zanussi TD4212W... • Answered on Sep 12, 2013
manual
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
1/14/2012 1:58:50 PM • Zanussi TD4212W... • Answered on Jan 14, 2012
My drier tc.481w water not going into tank
remove container/tank and clear drain line that runs into tank, Tim
5/29/2011 1:18:39 PM • Zanussi TD4212W... • Answered on May 29, 2011
My dryer is not heating
Hi, There is no condenser in this model of machine its an open vent machine so you will not find any water container etc.
For the reason above it sounds like your heating element may be faulty and needs replacing, you can try emptying the fluff filters and making sure that the exhast vent in not blocked or obstructed in any way, I have included a link ---> HERE <--- for the manual that will show you where the fluff filters are located, if this doesn't help then perhaps you will need to call an engineer out to look at it and perhaps replace the element.
Hope this helps.
2/14/2011 4:27:10 PM • Zanussi TD4212W... • Answered on Feb 14, 2011
I have replaced the capacitor on my dryer, and now
More than likely is the cause of your problem, you must reconnect it for it to work correctly.
11/4/2010 1:28:03 PM • Zanussi TD4212W... • Answered on Nov 04, 2010
The drum fails to start spinning, a humming sound
There might be a problem to the starting capacitor of your drier. Check the capacitor if it is working or not.
11/1/2010 5:01:56 PM • Zanussi TD4212W... • Answered on Nov 01, 2010
The Dryer is no longer producing hot air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
9/12/2010 2:17:42 AM • Zanussi TD4212W... • Answered on Sep 12, 2010
Tumble dryer 4212 no heat
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps.
7/19/2010 8:02:14 AM • Zanussi TD4212W... • Answered on Jul 19, 2010
Dryer not getting very hot so drying taking a
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
4/7/2010 10:39:29 PM • Zanussi TD4212W... • Answered on Apr 07, 2010
Zanussi TD4212W Electric Dryer Logo
36 questions posted
Top Zanussi Dryers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dryers
  • Zanussi Dryers
Most Popular Question
heater element in zanussi td 421
  • Dryers
