20 Most Recent ASUS T2-R Deluxe P4 Mini Barebone System Retail (ASUST2RDELUXE) Questions & Answers
USB not found
Open CPU cabinet and and install USB card window 98 operating is require USB driver and other operating system is automatic detect driver ....don't west time this is best way and second option format your he'd and re-install oprating system .....best of luck
3/1/2011 2:06:19 PM • ASUS T2-R Deluxe... • Answered on Mar 01, 2011
I need the setup disc for an ASUS V9950 Ultra Graphics Adapter
Hello the graphic card is maybe too old for win 7.But the vista driver works sometimes on windows 7Here is the 64 bit version: http://www.nvidia.com/object/winvista_x64_96.85_2.htmlAnd here the 32 bit:http://www.nvidia.com/object/winvista_x86_96.85_2.htmlHere is the main download page:http://www.nvidia.com/Download/index.aspx?lang=en-usRemember to select the driver for your system a 64 bit driver will not run on a 32 bit.If its not working with the drivers the graphic card must be renewedwith a card that supports windows 7. Good luck
10/31/2022 10:34:02 PM • ASUS Computers &... • Answered on Oct 31, 2022
5answers
An operating system wasn't found. Try disconnecting any drivers that don't contain an operating system. Press Ctrl+Alt+Del to restart and over and over what shall I do
You can go into the BIOS settings to see if the hard drive is shown there, if it is not then it is toast. You can also take it out and use another computer with a converter to test it for other issues. Or you can just replace the hard drive.
10/9/2022 4:52:13 PM • ASUS Computers &... • Answered on Oct 09, 2022
Asus A6R. I had to replace the battery because it emptied itself within 10 minutes.
wrong battery , sellers on ebay lie about them. many have no clue at all so only buy the battery stated in your users manual by technology type , and voltage, cell counts. (and phyical sizes and form factor) Asus A6R is a note book PC. the pack is custom sized (phy) snap in battery pack module. the tech is rechargeable lithium with 8 cells (series /parallel conn) 3.7v per cell. capacity 4400 mAh , 14.8V charged. like this. https://www.replacement-laptop-battery.com/asus-a6r-battery-14756.html learn not laptops charge. the charger is not in the power AC pack at all it is a chip on the mobo of the PC. main board. so there are 3 parts. 1: the DC /AC power park. warm never proves charging works. 2; the charge CHIP on mobo 3: and the batter, so never have just 1 battery so you know what is wrong, and AVOID NOS. AND THIS IS BOGUS 10.8V 4400 mAh ASUS.COM TELLS YOU THAT IS AND WAS WRONG. AND 10.8 Divided by 3.7 is 2.8 cells, how can that happen?, easy reading typo's online. and is bogus. sorry buy only new batteries.
9/14/2022 8:49:05 PM • ASUS Computers &... • Answered on Sep 14, 2022
Asus laptop/Rocketfish HDD problem transfering files? Windows 11 has modified the way some apps work
Posting follow-ups as a new post doesn't work here at Fixya because posts are not threaded by poster or subject. This post has absolutely no context to your previous question. The post here should have been posted as a reply to Larry Ng by clicking 'Comment' under his answer to you. FWIW, Larry is our Fixya computer guru and likely the only person on the planet that can fix problems like you have. He has knowledge like no other person I know! https://www.fixya.com/support/t29885843-using_asus_vivobook_win_11_want_send ..
8/18/2022 8:04:31 PM • ASUS Computers &... • Answered on Aug 18, 2022
Asus VH242 Monitor - the blue menu screen will pop open randomly and then scroll through all the options and I can not make it disappear again.
1. disassemble the monitor. 2. change the buttons for power and other function buttons. 3. always remember to replace with genuine parts.
8/13/2022 2:12:04 PM • ASUS Computers &... • Answered on Aug 13, 2022
Asus laptop x509ma won't turn on
Hi, It sounds like you've done the basic troubleshooting. Please call Asus to verify that you've not left any procedures out: 1 800-820-6655.And if this issue still persists, you can attempt to replace the laptop under your warranty. Thank you
7/28/2022 9:18:18 PM • ASUS Computers &... • Answered on Jul 28, 2022
Asus vh192d monitor power is auto off computer is running
that means the PC video out is dead. and all monitors show NO SIGNAL and go to sleep by law. TURN MONITOR ON LAST AND IT SHOWS NO SIGNAL, NO SYNC OR OUT OF RANGE ERROR BAD pc (none told)_ bad video card, bad cable or a dead PC. just because pC faNS SPIN DOES NOT MAKE IT GOOD.
7/16/2022 7:31:11 PM • ASUS Computers &... • Answered on Jul 16, 2022
I cant get gmail to give me a new password
ask them we are not them we can not ask for you. nor try to hack them. or just start over with new account, ask them is the answer. and told here like 10000 times contact them directly , as seen on their contract page online
6/9/2022 4:32:45 PM • ASUS Computers &... • Answered on Jun 09, 2022
How to reformat asus vivobook X202e WINDOWS 7?
so had w8 right and you meant down grade it to w7, from 8? if yes say so. the whole hdd will kill the os dead and gone 100% gone what to say is now to run recovery do you have the w7 install disk?s image recovery Restart your Notebook PC then press F9 per the manual if F9 is used, pC goes to w8 not w7 w8 sure does not have down grade option. w8 can be upgraded to w10 for free and is best. w7 is now an unsupported OS. w10 was offered too july 1015 for free then too. did you miss that great opportunity, or fear w10 ? w7 is not sold now over any counter w7 is not on the hdd image F9 only 8.1 is supported by oem make asus as seen here only 64bit 8.1 ( to get all drives and utilities) https://www.asus.com/US/supportonly/X202E/HelpDesk_Download/
6/9/2022 4:11:26 PM • ASUS Computers &... • Answered on Jun 09, 2022
Need asus rescue password for 2015/08/03
on what , not told WHAT, its computer related but WHAT fails?
6/9/2022 2:11:57 PM • ASUS Computers &... • Answered on Jun 09, 2022
Where do i find an operators manual for Asus c300
asus.com from 1995 to now, we love them. they are PRIME GRADE OEm as is DELL.
6/9/2022 2:11:03 PM • ASUS Computers &... • Answered on Jun 09, 2022
I puchaced from TAMSOLUTIONS a used Asus Motherboard. I would like to get the serial number for the motherboard.
ask ASUS that. only they know their sticker codes.
6/9/2022 2:06:02 PM • ASUS Computers &... • Answered on Jun 09, 2022
How To Fix Access Asus Router's Setting Page ?
lost the login PW then reset it ,using button marked the same on router. held for 10 seconds and released the login admin name and pw are reset to new factory state. asus.com RTM read the manual there.
6/9/2022 2:05:08 PM • ASUS Computers &... • Answered on Jun 09, 2022
Asus Router Tech Support ?
asus.com 1995 to now still there, ask them or on their contact page do as they tell you. same answer for any OEM device, PC or router ask the oEM for help. the manual is there too.
6/9/2022 1:56:24 PM • ASUS Computers &... • Answered on Jun 09, 2022
Mobo: p5g41c-mlx GPU: Asus GTS 450 1GB - - not compatible or am I just missing something?
old P5 mobo G41, Asus has super good support as does Gigabyte so the GTS fails in BIOS too? what happens not told at all. BIOS screens are first. and set BIOS to PCI GPU mode. do not use UEFI at all. or TPM ever. not overclocking , RIGHT? the card uses chip 450 made in , September 13, 2010 so is 12 years old. and will work on any old PC, before year 2012 fails on class 3,UEFI new PCs sure. but yours is not the GPU uses 106watts of power and the rear power jack called +12vPCI , is not connected to the PSU the card WILL FAIL for the lack of AUX power to that jack on rear of card GPU. 6Pin or 8. 2010 gpu in 2008 mobo is not ever hard to do ,but not resetting bios page 1. is never good , doing all this , reset bios defaults, nor hot swapping the card with AC power connected to the wall. the old P5 is only one, X16 slot so no errors there. possible 1 slot. . so you flashed the GTS to ***** why in the world flash any gpu card.? (panic?)_ looking to brick it? wow flashed the mobo and gpu card, now that is brave. why think flashing is the holy grail of PC service, it is not it is basics, most errors like this are basics.(wrong) power is first not last , 106 watts is 31 watts too much for any PCI-e slot and some PC the silly slot is under rated... making AUX 2 times more important. Corsair CX450 not 450m modular? the 450 has those old lame now 4pin molex PATA drive power cables for year 2001 PC, why us this dog.? and not modern PSU. yes the cx has PCI-Express Connector 1 x 6+2-Pin and EVGA has like 25 models of 400watt PSU. so can not read your manual on it to see if it has this key cable PCI-Express Connector 1 x 6+2-Pin see left jack 8 and 6 , the GPU needs 1 or the other OR WILL FAIL. power is first, no flashing any bios. I call them GPU AUX power, and are not optional ever if seen on the card. atx-spec-molex-undefined-undefined-0.png other cause of failure for sure bios menus dead in mobo are they? 1: that 12 year old mobo coin cell is NO GOOD that be first./first 1b:above power cable not connected. to GPU. 2: turn off all UEFI features in MOBO this card is not UEFI certified. 3: reset mobo bios in bois page one. 4: never turn on TPM in bios. 5: do not use bios secure boot. 6: set time and date in bios 7: never hot swap any parts inside this PC, (ac cord pulled from wall first) 8: flashed it and bricked like millions did this year, why?
6/9/2022 1:54:38 PM • ASUS Computers &... • Answered on Jun 09, 2022
Does Anyone have a manual for Asus VS238H-P monitor?
https://www.manualslib.com/products/Asus-Vs238-Series-9073741.html
5/25/2022 10:26:58 AM • ASUS Computers &... • Answered on May 25, 2022
A power surge prevents my ASUS P1801 from booting to the "enter password" window. Am able to use the android system, but not the Windows 10 system.
2012 PC with firmware AndroidAIO, ALL IN ONE FAKE DESKTOPS. SURE.and now the w8 new PC and now w10 OS is deadand hdd dead. cause.IT CAME NEW WITH 1TB HDD (PC) + 32GB eMMC Flash (Tablet)W10 DOES NOT EVER BELONG ON THAT 32BG EMMC DRIVE IF THERE.SEEMS TO ME IT IS BUT specs on this PC are weak. AS W10 UPDATES WILL FAIL ******* SUCH A TINY DRIVE.for major updates, lots of PC made cheap with no real SSD say 128GB up, all failed on 32GB ssd or eMMCvast did, google that and see.https://www.asus.com/supportonly/P1801/HelpDesk_Manual/manual:https://dlcdnets.asus.com/pub/ASUS/DigitalHome/DAV/P1801/E7705_P1801.pdfdells failed toohttps://www.dell.com/support/kbdoc/en-us/000131941/windows-10-needs-more-space-for-update-on-32gb-storage-devicesand googled (brave)https://search.brave.com/search?q=windows+10+++update+failed+on++32GB&source=webnothing hew here, a huge problem back in the 30GB days.
3/24/2022 8:59:04 PM • ASUS Computers &... • Answered on Mar 24, 2022
Usb port collapsed at cable end.
asus laptop>? what model>how old is it, if bought new.?10 years , 20?I ask that for 2 reasons, but one is parts can be sourced to fix it.if not too oldand tell me how good the USB really are.and yes I have seen and fixed all kinds of bad USB ports even broken.
3/24/2022 12:57:41 PM • ASUS Computers &... • Answered on Mar 24, 2022
ASUS T2-R Deluxe P4 Mini Barebone System Retail (ASUST2RDELUXE) Logo
Popular Tags
1 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Marvin
Marvin
Mehandi Husain ...
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
usb not found
  • Computers & Internet
