20 Most Recent Reebok R 5.10 SpaceSaver Elliptical - iFit Live Compatible 3-Position Questions & Answers
2answers
My Reebok ZR10 is giving the message: Current Overflow and is completely seized up. What does this mean and is there a solution?
it needs service the motor current is to high and jammped. due to bad belt parts or the motor itself , a tech with turn the parts by hand to see if they or what is jammed. or gear box there. get it fixed ? ok:
3/20/2024 3:19:46 PM • Reebok Exercise... • Answered on Mar 20, 2024
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Treadmill repair : r/fixit
Reddit · r/fixit 3 comments · 4 years ago Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2 Which part of my broken treadmill should I try replacing? - Reddit Apr 18, 2020 Urevo 2-in-1 giving e10 error message- did you encounter this ... Oct 10, 2022 Need help with Sole F63 treadmill error code - Reddit Nov 21, 2022 More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits https://forum.allaboutcircuits.com > threads > reebok-j... Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ... Missing: GT30 ‎' Show results with: GT30
Treadmill Support - Reebok Fitness
reebokfitness.info https://www.reebokfitness.info > treadmill-support View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock. ..
1/8/2024 7:37:07 PM • Reebok Exercise... • Answered on Jan 08, 2024
2answers
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
12/8/2023 9:47:55 PM • Reebok Exercise... • Answered on Dec 08, 2023
Reebok treadmill e13 error message
f the E13 error code is still showing after restarting your treadmill, check to ensure that the wiring between the AC motor drive and motor cables is securely connected. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.
11/5/2023 11:24:19 PM • Reebok Exercise... • Answered on Nov 05, 2023
Reebok 8000ES stuck incline position will not decline.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj79pDHxZSCAxV_AHkGHbhiDxkQFnoECBsQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Ffitness-equipment%2Fgdah0-reebok-8000es-treadmill-incline-keeps-going.html&usg=AOvVaw0mEH-BLg44uwLpy6jJGb3K&opi=89978449
10/26/2023 8:24:11 PM • Reebok Exercise... • Answered on Oct 26, 2023
I have a Reebok ZR9 Treadmikk stuck in the incline position and showing error 1 whwn switched on. I have checked for lose connections Please can you help.
Check the incline motor: If resetting the treadmill doesn't work, it's possible that the incline motor is faulty and needs to be replaced.
8/27/2023 3:28:48 PM • Reebok Exercise... • Answered on Aug 27, 2023
Reebok ZR9 X-Trainer. is there an extractor for removing the cross brace? What thread is the cross brace?
Here is the assembly instructions. I doubt an extractor is needed. https://cdn.sweatband.com/upload/multimedia/RE1-11810-ZR8%20CROSS%20TRAINER%20ASSEMBLY%20GUIDE.pdf Assembly video. You will be working in reverse. https://www.youtube.com/watch?v=6cA7cbsYr_I Threads will be metric fine and are shown in the instructions, M5, M8 etc. ..
6/1/2023 4:23:48 PM • Reebok Exercise... • Answered on Jun 01, 2023
Reebok ZR8 Treadmill error code E01
If the E1 error occurs after the belt starts to move for several seconds, the error code means that the system is not picking up the speed of the motor. This pickup comes from a magnet mounted on the front roller pulley and a speed sensor, or a problem with the magnet.Feb 29, 2016
E1 Error Codes - The Treadmill Engineer
treadmill-engineer.com http://www.treadmill-engineer.com > 2016/02 > e1-error...
Reebok ZR9 treadmill has E01 error on console since ...
JustAnswer https://www.justanswer.co.uk > electronics > ca4k2-ree... Reebok ZR9 treadmill has E01 error on console since moving · 1. Turn the machine off at the mains socket for at least 30 seconds · 2. Turn the machine on at the ... ..
5/31/2023 3:59:25 PM • Reebok Exercise... • Answered on May 31, 2023
Reebok GTS40 treadmill not working
Hi Chris,Hope so you're doing well, fact that it runs briefly and then flips the fuse suggests a potential overload or short circuit problem. To troubleshoot the issue, start by checking the power source and ensuring that the circuit breaker or fuse can handle the treadmill's electrical load.Inspect the power cord for any signs of damage, fraying, or loose connections. Make sure it is securely plugged into the outlet. Additionally, examine the motor control board for any visible signs of damage, such as burnt components or loose wires.Testing the motor by disconnecting the power and manually rotating the treadmill belt can help identify any obstructions or issues with the motor or belt tension. If you are unable to identify or resolve the problem on your own then download now user guide, it is advisable to consult a qualified technician or contact the manufacturer's customer support for further assistance.Hope so this will help you!Regards,Bryce JuneCEO & Founder of https://trafficriderapp.com/
5/26/2023 7:25:56 AM • Reebok Exercise... • Answered on May 26, 2023
Reebok One GT40S Treadmill. Hi, should I be able to adjust my settings using the LCD screen on my new treadmill.
Just so you know, we aren't Rebook we are Fixya and just have a Reebok category for filing questions. Videos showing how they work.
4/23/2023 7:04:08 PM • Reebok Exercise... • Answered on Apr 23, 2023
Reebok GT40 S Treadmill. The touchscreen keeps freezing once I click on an app. Then works and cuts out after a minute of working.
Question edited for clarity. Question moved from Cellphones category. Limited help here, but there is a link to Reebok https://www.google.com/search?q=Reebok+gt40s+touch+screen+keeps+freezing ..
3/20/2023 11:47:28 PM • Reebok Exercise... • Answered on Mar 20, 2023
Reebock REM-1200 Power Bike. Where can I get a battery replacement please?
Question edited for clarity. Batteries 4 x 1.5V - size C Manuals https://www.google.com/search?q=reebok+rem-11200+power+bike ..
3/3/2023 4:01:19 AM • Reebok Exercise... • Answered on Mar 03, 2023
Reebok ONE GT40s incline working intermittently
It sounds like there may be an issue with the incline motor or the lifting mechanism. Here are a few troubleshooting steps you can take:
  1. Check for any visible damage or obstructions in the incline mechanism. Make sure that there is nothing blocking the movement of the incline motor or lifting mechanism.
  2. Check the wiring and connections for the incline motor. Make sure that all wires are connected securely and that there are no loose or damaged wires.
  3. Test the voltage going to the incline motor. Use a multimeter to check that the motor is receiving the correct voltage.
  4. Try to manually adjust the incline. This will help you determine if the issue is with the motor or the lifting mechanism. To do this, unplug the treadmill and remove the motor cover. Locate the incline motor and manually turn the screw with an Allen wrench to raise or lower the incline. If the incline moves smoothly and easily, the issue is likely with the motor. If the incline is difficult to move or doesn't move at all, the issue is likely with the lifting mechanism.
If you're not comfortable performing these steps, it may be best to contact a professional to diagnose and repair the issue.
2/26/2023 9:44:19 AM • Reebok Exercise... • Answered on Feb 26, 2023
My Reebok 9500 ES Treadmill is stuck at it's max incline.
  1. Check the belt: Make sure the belt is properly aligned and tensioned, as a misaligned or loose belt could cause the incline to get stuck.
  2. Check the incline motor: If the incline motor is not functioning properly, it could be preventing the incline from moving. You may need to have the motor inspected or replaced.
  3. Check the incline sensors: If the incline sensors are not functioning properly, they could be preventing the incline from moving. You may need to have the sensors inspected or replaced.
  4. Check the control board: If the control board is not functioning properly, it could be preventing the incline from moving. You may need to have the control board inspected or replaced.
If these steps do no
2/11/2023 5:08:43 AM • Reebok Exercise... • Answered on Feb 11, 2023
My reebok gt40s not working. The display shows E2 error. What shall I do?
It sounds like you're experiencing an E2 error on your Reebok GT40s treadmill. This error is indicative of a problem with the speed sensor, which may need to be replaced. Additionally, check your cables and connections to make sure they are all securely plugged in
1/30/2023 5:14:13 PM • Reebok Exercise... • Answered on Jan 30, 2023
3answers
My Reebok GT40S Treadmill has stopped working. When powered on it just clicks and no display appears. I have checked the only visible fuse I can see on the treadmill and that is working fine.
You need a new control board - around 65 UK pounds from Reebok (in uk) and pretty easy to fix. Remove 4 screws from plastic motor cover and remove cover. Loosen the circuit board hold-down screws (x2) then take phone/ipad photographs of board connections to aid re-assembly. Disconnect the 6 or 7 leads from their spade connectors. Fit new board, reconnect the leads in the same place using the photographs then, fit the two board retaining screws and replace the cover and 4 screws. Job done!
1/17/2023 8:53:47 PM • Reebok Exercise... • Answered on Jan 17, 2023
Hi ya, I have a Reebok Z9 Treadmill creaks only on incline.
Get some of this and spray every bolted joint or piece that rubs you can find. You can also lubricated the belt with it.
Jig-A-Loo - invisible silicone-based lubricant and water ...
https://www.jigaloo.ca Jig-A-Loo, an invisible silicone-based lubricant and water-repellent that doesnt stain or stink. It stops squeaks, lubricates, loosens and prevents rust and ... ‎Seriously works · ‎Garage Door Lubricant · ‎MSDS & product safety · ‎Contact us ..
1/8/2023 9:45:27 PM • Reebok Exercise... • Answered on Jan 08, 2023
Reebok R 5.10 SpaceSaver Elliptical - iFit Live Compatible 3-Position Logo
3 questions posted
Top Reebok Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Reebok Exercise & Fitness
Most Popular Question
reebok gts40 treadmill not working
  • Exercise & Fitness
