20 Most Recent ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
ya cause u r using a normel empty cd u need to get a re writeable cd or make the cd as data cd>and in the soft ware like nero u have a option under the advance settings that u need to check on that which is (do u burn this cd in future)try this
ASUS CB-5216A... | Answered on Mar 25, 2020
see if the bios sees it first of all. If it does, then go to Windows management, click on disk management, select the disk, and give it a disk letter. Windows can't see it if it doesn't have a letter assigned to it.
ASUS CB-5216A... | Answered on Aug 02, 2017
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
ASUS CB-5216A... | Answered on Jul 24, 2011
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
ASUS CB-5216A... | Answered on May 12, 2011
you might have to physically unplug the leads for this cd/dvd then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
ASUS CB-5216A... | Answered on Apr 28, 2011
FOLLOW THESE STEPS TO CLEAR YOUR MEMORY BUFFER OVERFLOW ISSUES
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
ASUS CB-5216A... | Answered on Jan 28, 2011
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
ASUS CB-5216A... | Answered on Dec 11, 2010
try this
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
then uninstall and reinstall the burning s/w on the system .... thanks
ASUS CB-5216A... | Answered on Oct 02, 2010
use from dvd burner to putting some special files that need for dvd players.only write your movies on movie mode!
ASUS CB-5216A... | Answered on Aug 11, 2010
check cables.if they are ok,re-install drivers.the disable drive from device manager & restart the pc
This IS a CD Drive.
ASUS CB-5216A... | Answered on Aug 07, 2010
have the same same problem unsolved yet. it's not on the software actually, it's in the installation of the drive...
ASUS CB-5216A... | Answered on Jul 10, 2010
replace it or contact your local dealer
ASUS CB-5216A... | Answered on Jun 07, 2010
Open the computer case, disconnect the power and data cables from the drive and remove it from the case. How you do this will depend on the type of case your computer has. There may be screws on both sides of the drive, one side only, or no screws in a tool-less case where there will be some kind of release tabs so you can slide the drive out.
Once you have the drive out of the computer, there are four screws in the bottom that hold the drive together. Take those out, take off the top cover and you'll be able to get at whatever's stuck in the drive. Just be careful if the sticker is near the laser lens. If you poke too hard the pickup assembly can be damaged and you'll be replacing the drive.
In fact, with new drives only around $30, it might be easier and just as cost-effective simply to replace it right off.
ASUS CB-5216A... | Answered on Mar 10, 2010
lens is not working, u need to replace ur dvd drive
ASUS CB-5216A... | Answered on Feb 28, 2010
Hl
You must buy asus external drive its worth
Harry
ASUS CB-5216A... | Answered on Aug 12, 2009
dear renzp6
try to clean the rom with lens cleaner.
or you have to replace it with new one.
ASUS CB-5216A... | Answered on Dec 06, 2008
hi , please try this steps
restart the system then check for the drive
ASUS CB-5216A... | Answered on Nov 16, 2008
ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM (Combo) Burner Logo
33 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asuscb 5216a cann 39 t read dvd
  • Computers & Internet
