20 Most Recent
ASUS A7S266-VM/U2 (A7S266-VM/U2/LAN) Motherboard Questions & Answers
1GB PC400 RAM does not work with motherboard A7S266-VM/U2
Hello the home page is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=10&m=A7S266-VM%2fU2&os=&hashedid=n%2faIf any drivers or manual needed select first your windows.Click on global for download.Unzip the file and you need a pdf reader (adobe) to read the content.Here are some
specification about you mainboard:
2 x DDR DIMM Sockets
Max.2GB unbuffered PC2100/PC1600 non-ECC SDRAM Memory
2 x SDR DIMM Sockets
Max.2GB unbuffered PC133/PC100 non-ECC SDRAM Memory
(Note: DDR ram and SD ram memory can not be used on A7S266-VM/U2 simultaneously) This means you can`t use SD RAM together with DDR ram.The bios could have a setting for this because of the use of 2 different ram types.Try downloading the manual.Good luck
11/18/2012 10:06:10 PM •
ASUS...
Answered
on Nov 18, 2012
A7s266-vm/u2 VGA Drivers
You can get it here : http://support.asus.com/download/options.aspx?SLanguage=en&type=1
OR
Download this Software : CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
* just install the software and RUN it.
* scan drivers
* then install (your desire driver)
6/26/2011 6:52:13 AM •
ASUS...
Answered
on Jun 26, 2011
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
My asus laptop turns on but there is just black, the power indicator says its on.
If you are experiencing a black screen issue on your laptop, the first thing you should do is to make sure your laptop is powered up correctly. Check the cable from the power adapter to the laptop, and make sure it is firmly plugged in. If it is, then you should try resetting the power supply on your laptop. To do this, unplug the power adapter from the laptop, press and hold the power button for 30 seconds, and then plug the power adapter back in. If the laptop still does not display any images, you should try reseating the RAM chips. First, try to turn off and unplug your laptop, and then remove the battery. After that, open up the RAM memory slot, and use a screwdriver to press down on the RAM chip securely. Then, replace the RAM chips and the battery before turning on your laptop. If these troubleshooting steps do not work, then it is likely that your laptop may have a hardware issue, and you should take it to a repair shop.
MY ASUS T100 keyboard is not working.
Double check that the tablet is sitting properly in the keyboard
Is this the model where you can charge via the keyboard - plug the charger into the keyboard?
Reply with more info
AMD Ryzen 5 5600G causes BSOD after instaling graphics driver
t is possible that the issue is related to a driver conflict or compatibility issue between the graphics driver and the operating system. Here are some troubleshooting steps you can try:
- Update the graphics driver: Download the latest version of the graphics driver from the AMD website and install it. This may resolve any compatibility issues that were present in the previous driver version.
- Run Windows Update: Check for any available updates for your operating system and install them. This can resolve any compatibility issues with the graphics driver and other system components.
- Check the device manager: Open the device manager and check if there are any issues with the graphics card or other devices. You may need to update or reinstall the driver for the device.
- Check the system memory: Use a memory diagnostic tool to check if the system memory is working properly. Faulty memory can cause BSOD errors.
- Check the power supply: Insufficient power supply can cause system instability and BSOD errors. Check if the power supply is adequate for the system configuration.
- Disable or remove any third-party antivirus or firewall software: In some cases, these programs can interfere with the graphics driver installation or cause conflicts with system components.
If none of these steps resolve the issue, it may be a hardware problem with the graphics card or the motherboard
