20 Most Recent
Altec Lansing ACS 295 Computer Speakers Questions & Answers
Hi, well if you have NO Green LED then this means that you do not have power coming into the unit. You need to check, your power lead, if it is all OK, there is power at the socket, then unfortunately, the Power Supply has "Blown". It will need to be repaired, any repair like this usually is fairly simple. however as with any repair, if you get it attended to by a professional (recommended) always ask for a 'Quote" before allowing any repair work to commence.I see similar things in my shop frequently, a repair such as this if straight forwards should cost under $55.00 + parts for repair.
Altec Lansing...
Answered
on Jul 19, 2011
Hi names Rui try downloading the sound driver here
http://www.computerdriverfinder.com/altec-driver.php you will find all the latest sound drivers for altec lansing in this site if it still doesn't work try calling costomer service so they can provide you with better solutions..try to dl a driver 1st if all else fail that your last option.....
Altec Lansing...
Answered
on Jul 19, 2011
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Altec Lansing...
Answered
on Nov 11, 2010
Have you tried another set of speakers in your system? even a pair of headphones (directly connected to your soundcard, not the headphone port you can have on your speaker control)? If you get good sound through headphones/other speakers- it's likely a fuse in the subwoofer or the speaker set itself has gone bad. Usually the subwoofer has the power unit for the speaker set- check and see if the fuse has blown. If so, you can get a replacement either from a place like Home Depot, Radioshack, your local hardware store, even Autozone or Advanced Auto (even Wal-Mart usually has a few fuses). Check the documentation for your speakers to make certain you get the correct amperage fuse- too low, it will blow the fuse again; too high: it blows the speakers. I’m happy to help further over the phone at
https://www.6ya.com/expert/susan_42b401e0b1603d8a
Altec Lansing...
Answered
on Oct 13, 2010
TRATA AQUI http://www.altecpro.com/support/professionals.htm
Altec Lansing...
Answered
on Oct 12, 2010
The green jack goes to the green jack on the back off your tower.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Altec Lansing...
Answered
on Sep 05, 2010
ever computer speaker has a cord for connecting it to the pc. in most cases just a single cord does the trick (you do not need the out 2 lead to use it) unless it is a sophisticated speaker such as one for studios.
good luck
Altec Lansing...
Answered
on Jul 04, 2010
