20 Most Recent
ASUS VIA KT266 Chipset A7V266 Motherboard Questions & Answers
I have a Windows 2000 ASUS PC and a legacy Compaq W17q 14' monitor
It sounds like you have an older computer and monitor. Windows 2000 is a legacy operating system that is no longer supported by Microsoft, and it may not be compatible with newer hardware or software.
If you're having trouble getting your ASUS PC and Compaq W17q 14' monitor to work together, there are a few things you can try. First, ensure that your PC is set to the correct resolution and refresh rate for your monitor. This can usually be done by going into the display settings in Windows 2000.
You may also try adjusting the settings on the monitor itself, such as the contrast and brightness. Additionally, you may have to install the correct drivers for your monitor in order for Windows 2000 to recognize it. You can check the manufacturer's website for the drivers that are compatible with your monitor and Windows 2000.
It's also important to note that older hardware may not be able to support the features and resolutions of newer monitors and may not be able to achieve the best display quality. If you are experiencing display issues, it may be worth considering an upgrade to newer hardware and a monitor that is more compatible with your current operating system.
Why does my PC starts then restarts when I hit the start button?
There could be a number of reasons why your PC is starting and then immediately restarting when you press the start button. Here are a few things you can try to troubleshoot the problem:
- Check the power supply. Make sure the PC is receiving power and the power supply is working properly. Check the outlet and circuit breaker to ensure that the PC is getting electricity.
- Check the hardware. A faulty component, such as a failing hard drive or RAM module, can cause the PC to start and then immediately restart. Try removing and reinserting any removable hardware, such as RAM modules or expansion cards, to see if this resolves the problem.
- Check the software. A software issue, such as a corrupt operating system or malware, can cause the PC to start and then immediately restart. Try booting the PC in safe mode and see if it starts and stays on. If it does, there may be an issue with the software on the PC.
- Check for loose connections. Make sure all of the cables and connections inside the PC are secure. A loose connection can cause the PC to start and then immediately restart.
I recommend having a mechanic diagnose the problem in order to determine the cause and recommend the appropriate repair. I hope this helps! Let me know if you have any other questions.
Asus A6R. I had to replace the battery because it emptied itself within 10 minutes.
wrong battery , sellers on ebay lie about them.
many have no clue at all
so only buy the battery stated in your users manual
by technology type , and voltage, cell counts. (and phyical sizes and form factor)
Asus A6R is a note book PC.
the pack is custom sized (phy) snap in battery pack module.
the tech is rechargeable lithium with 8 cells (series /parallel conn)
3.7v per cell.
capacity 4400 mAh ,
14.8V charged.
like this.
https://www.replacement-laptop-battery.com/asus-a6r-battery-14756.html
learn not laptops charge.
the charger is not in the power AC pack at all
it is a chip on the mobo of the PC. main board.
so there are 3 parts.
1: the DC /AC power park. warm never proves charging works.
2; the charge CHIP on mobo
3: and the batter, so never have just 1 battery so you know what is wrong, and AVOID NOS.
AND THIS IS BOGUS 10.8V 4400 mAh
ASUS.COM TELLS YOU THAT IS AND WAS WRONG.
AND 10.8 Divided by 3.7 is 2.8 cells, how can that happen?, easy reading typo's online. and is bogus. sorry
buy only new batteries.
Asus laptop x509ma won't turn on
It sounds like you've done the basic troubleshooting. Please call Asus to verify that you've not left any procedures out: 1 800-820-6655.And if this issue still persists, you can attempt to replace the laptop under your warranty. Thank you
Asus vh192d monitor power is auto off computer is running
that means the PC video out is dead.
and all monitors show NO SIGNAL and go to sleep by law.
TURN MONITOR ON LAST
AND IT SHOWS NO SIGNAL, NO SYNC OR OUT OF RANGE ERROR
BAD pc (none told)_ bad video card, bad cable
or a dead PC.
just because pC faNS SPIN DOES NOT MAKE IT GOOD.
I cant get gmail to give me a new password
ask them we are not them
we can not ask for you.
nor try to hack them.
or just start over with new account,
ask them is the answer. and told here like 10000 times
contact them directly , as seen on their contract page online
How to reformat asus vivobook X202e WINDOWS 7?
so had w8 right and you meant down grade it to w7, from 8?
if yes say so.
the whole hdd will kill the os dead and gone 100% gone
what to say is now to run recovery
do you have the w7 install disk?s
image recovery
Restart your Notebook PC then press F9 per the manual
if F9 is used, pC goes to w8 not w7
w8 sure does not have down grade option.
w8 can be upgraded to w10 for free and is best.
w7 is now an
unsupported OS.
w10 was offered too july 1015 for free then too. did you miss that great opportunity, or fear w10 ?
w7 is not sold now over any counter
w7 is not on the hdd image F9
only 8.1 is supported by oem make asus
as seen here only 64bit 8.1 ( to get all drives and utilities)
https://www.asus.com/US/supportonly/X202E/HelpDesk_Download/
How To Fix Access Asus Router's Setting Page ?
lost the login PW
then reset it ,using button marked the same on router.
held for 10 seconds and released
the login admin name and pw are reset to new factory state.
asus.com
RTM read the manual there.
