ASUS Computers & Internet • Uploaded on Oct 02, 2013
The issue may be related to the voltage setting of your memory modules. The standard operating voltages of DDR2 and DDR3 memory modules, as defined by JEDEC, are 1.8V and 1.5V, respectively. However, some of the memory modules require higher operating voltage than JEDEC's standards. In such case, the memory may sometimes not be able to function properly without enough voltage.
When you encounter instability issue, please first check the operating voltage of your memory modules, and please manually set the memory voltage accordingly in the BIOS.
Hope that helps
Christopher
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this will help don
71 questions posted
1,357 Questions
705 Questions
590 Questions
517 Questions
494 Questions
