20 Most Recent
ASUS P5AD2-E Premium Motherboard Questions & Answers
How do i upgrade bios
Hello download the bios version here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5AD2-E%20Premium&p=1&s=22By selecting your windows system.Open bios folder, and click global for download, for the newest bios version.Download also
ASUS Update, In utility, and please unzip both files.Install
first asus update, and run the program, select update bios from file, and select the bios
version you have downloaded, the rom or bin file, and click next.Now the bios update process will begin.DO NOT turn off the power, when the process is running, and you have to setup the whole bios, when the job is done.Follow the instuctions on screen, when you have rebooted.Good luck
My Asus P5AD2 mother board bios wont detect my
double check cable from the mainboard to your hardisk like IDE or SATA together with the power cord
just make sure if its fully inserted. boot up the the pc press delete to check UP THE BOIS IF THE HARDISK is connected.
let see how it works.....
Hi!
i am nick
i have a
Hi! My name Mace and I'm here to help.
When you turn on your computer after system reads, "Press F1 to continue" appears. This means that there is an internal error in your computer.
It can be a problem in your hardware, or wrong configuration in your CMOS setup. But as you said a girl told you that the temperature inside your computer is too high. I suspect that one of your fan or blower is not working.
Open the casing of your CPU while it is turn on. See which of the blower that is not working then replace it with new one.
Hope this is enough information to fix your computer. Good luck and post another message if you still have other question. Thank you for using Fixya.
Need new motherboard
You can purchase one off Ebay the powerseller has 5 of them available
CLICK HERE for a direct link to the page.
Hope this helps you with what you need, I couldn't find one on asus or a few other parts websites I buy things from. Feel free to leave positive feedback if this helps.
PC wont boot
The first thing to do would be to remove all non-essential hardware from the box, I mean everything. This will help isolate the problem.
Then remove all the RAM except the very basic amount. If it still doesn't work, swap out the installed RAM with the RAM you pulled possible and try it. This will isolate a RAM issue.
If that doesn't do it, you may also consider swapping out the video card. Before we go any further, try these things and report back.
Good Luck!
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
