20 Most Recent Averatec 1000 Notebook Questions & Answers
2answers
My DVD wont recognize any DVDs. This just started today.
Well, DVD Drives do burn out, and while you probably don't want to hear it, you might have to buy a new one. If you have restarted the computer several times, and haven't installed anything lately, then it may just be dead. But you should try to remember if you have installed anything lately, or done anything to change the laptop. Also, see if it will read CD's, or if it makes noise like the CD/DVD is spinning up/down or the eye is moving back and forth when you insert it. Good Luck
6/5/2020 8:54:13 AM • Averatec 1000... • Answered on Jun 05, 2020
Averatec 1000 webcam doesn't work
Integrated webcams are not useable with the Windows 7 OS. Windows XP had webcam software that enabled you to use the camera, as does Windows 8, 8.1 and 10. The patch to solve the issue with the integrated webcam using Windows 7 was never resolved... Not to my knowledge anyways. It would always come up with the message that the webcam was "Already in use by another program".
2/3/2018 11:40:23 AM • Averatec 1000... • Answered on Feb 03, 2018
I am trying to download
You can try and using a third party application liek driver booster. Driver Booster 3 Free
7/15/2017 3:54:59 AM • Averatec 1000... • Answered on Jul 15, 2017
How do i know which of my hdd partitions hold the OS?
Go to My Computer (or Computer) and the partition on which is the OS installed has the Windows logo over it (Windows Vista and newer). In most cases the OS is installed on the C: partition.
9/26/2014 5:57:28 PM • Averatec 1000... • Answered on Sep 26, 2014
I forgot my administrators password
Sorry for my form solution, but the answer is there. GLLost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly
11/23/2012 5:42:38 PM • Averatec 1000... • Answered on Nov 23, 2012
Please help me....if how to reset the HDD password of my netbook (averatec N1140 Series)...
You can reset netbook password by Smartkey Windows Password Recovery, just do as the following steps,Step1: Download Windows Password Recovery Enterprise and install on any available PC. Step2: Burn Windows password reset CD/DVD or USB to reset lost Windows password. Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive. Step4. Reset lost Windows password to Re123456 together with the burned CD/DVD or USB Flash Drive.
5/22/2012 2:17:41 AM • Averatec 1000... • Answered on May 22, 2012
My battery wont charge
time to buy a new battery If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
5/13/2012 6:26:57 AM • Averatec 1000... • Answered on May 13, 2012
0answers
When I'm attempting to log
try starting ur windows in safe mode. once you logged in do a system restore. it will solve ur problems. if not send me a comment.
good luck
9/3/2011 11:16:47 AM • Averatec 1000... • Answered on Sep 03, 2011
My friend owns this averatec
The notebook could be overheating.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
5/7/2011 10:29:12 AM • Averatec 1000... • Answered on May 07, 2011
0answers
Space barwon'twork
without more information, nobody can even attempt to help you. Why nobody on here took the time to tell you that is beyond me.
2/14/2011 1:42:36 PM • Averatec 1000... • Answered on Feb 14, 2011
2answers
How can i restore my 1000 to factory settings?
hi there,
try f11 or f12 or f2 or f1 and see if that helps
11/25/2010 6:33:09 PM • Averatec 1000... • Answered on Nov 25, 2010
I am looking for a copy of the factory restore
I am trying to do the same thing. Included plastic cd case with original box states to hit the f4 key once averatec logo appears. I tried this along with every other key and nothing brought up the recovery software screen.
11/23/2010 6:32:44 PM • Averatec 1000... • Answered on Nov 23, 2010
How do you turn on your webcam?
Press and hold the Fn button, and then press the F6 button to turn the Webcam function on. Press again to turn it off
I looked at the user guide which is located here. You'll need Adobe reader to read the guide since its in a PDF.
http://www.trigem.com/upload/America/product/Averatec%201000%20Users%20Guide.PDF
11/3/2010 1:46:16 AM • Averatec 1000... • Answered on Nov 03, 2010
Shows that i have an
try to check the internet settings..maybe all websites are block..
8/20/2010 4:46:50 AM • Averatec 1000... • Answered on Aug 20, 2010
Knocking sound from inside averatec 1000
This looks like a hard disk drive problem, I think that you must be hearing a clicking sound. Which means that your hard disk has a lot of bad sectors and eventually they will increase resulting in hard disk failure.
Does your laptop boots, or are you at the last stage.
This can be fixed but its a very complicated and lengthy process, thats why I would recommend you to get a new hard disk or get it repaired by a computer tech. Compare the prices and go for the cheapest one.
Please feel free to ask me any further.
4/9/2010 8:46:53 PM • Averatec 1000... • Answered on Apr 09, 2010
Averatec 1000 Notebook Logo
54 questions posted
Top Averatec Computers & Internet Experts
David Shaub
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Averatec Computers & Internet
Most Popular Question
friend owns averatec
  • Computers & Internet
