20 Most Recent
Battery Technology Battery for Evo N610 Compaq (CQEB600) PC Notebook Questions & Answers
Battery
You could do a search on the serial and or model number.
6/11/2007 5:27:22 PM •
Battery...
Answered
on Jun 11, 2007
Changing Backup Battery on LG Ls50
hte battery pack is located at the buttom towards the screem hinger. there are 2 latches, one for each side. slide the latch toward the edge of the laptop and slide the battery out.
install in reverse order.
11/13/2012 2:07:03 AM •
Battery...
Answered
on Nov 13, 2012
My computer keeps dying and
Newer versions of OSX will tell you if your battery needs replacing simply by clicking on the charge indicator on the top toolbar. If you have not updated check out this free application
http://www.coconut-flavour.com/coconutbattery/ this will tell you the current condition of your battery and if you need to get a replacement.
How old is your Macbook? If you are still under warranty or have AppleCare, Apple should replace the battery for free if it is not holding a charge.
2/28/2011 12:54:46 PM •
Battery...
Answered
on Feb 28, 2011
How to sign into [email protected]
Left-click where your browser has www.FixYa.com, when this web address (URL) is highlighted in blue, type in
www.hotmail.com (or click on the hotmail link in this message), then when prompted
for Username, enter "yengbe" (without the quote marks) then press the TAB key, then enter
your password.
2/27/2011 11:06:47 AM •
Battery...
Answered
on Feb 27, 2011
Can I use the DELL Inspiron 6400 without the
Without BOTH the battery AND the charger, the only use for your computer is as a door-stop. :-)
Yes, the battery can easily be removed.
Turn the computer off.
Disconnect the AC power.
Flip the computer upside down.
Look for a "lock/unlock" button or slider.
Move the button or slider to the "unlock" position.
Carefully and slowly turn the computer right-side up,
and the battery should easily fall out of its socket, hitting your foot.
Reconnect the AC power, and start-up the computer.
12/30/2009 2:49:54 PM •
Battery...
Answered
on Dec 30, 2009
Laptop Battery
If your laptop is more than two years old, this might be due to the endup of battery life. You have to replace your battery pack. But the system date and time is not maintained through the main battery, there is a small battery pack attached with the motherboard that can be accessed by removing the underneath cover. Also change the motherboard battery pack to solve the problem of time resetting to factory default. Hope this will be helpful
9/21/2009 10:04:11 AM •
Battery...
Answered
on Sep 21, 2009
I Have a Toshiba satelite laptop. It has a week
you have a bad plug on the end of the power supply a loose jack on the computer or a bad power supply you need to test the power supply with a volt meter to see if it is putting out any power if it is you have a bad connector on the pc or an intermittent connection on the power plug end. get a new battery before you blow something up. it is not good for the power supply to run the compputer all the time. it will shorten the life.
7/18/2009 9:46:14 AM •
Battery...
Answered
on Jul 18, 2009
Dell laptop doesnt charge only runs on ac power
How long have you had the laptop as all batteries even rechargeable have a limited life span. Dell laptop batteries normally have a life span of 1 to 2 years, so you may need to buy a new one
4/20/2009 12:26:10 PM •
Battery...
Answered
on Apr 20, 2009
Como cancelar el winter driver
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
