20 Most Recent Altec Lansing ADA 215 Computer Speakers Questions & Answers
try swapping the speakers around if the problem still persists either the speaker is faulty or the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems hope this helps
Altec Lansing... • Answered on Apr 10, 2011
Email this person she is customer support at altec , very helpfull person [email protected]
Altec Lansing... • Answered on Mar 19, 2011
if your computer came with a disk the sound drivers could be on it control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
Altec Lansing... • Answered on Nov 22, 2010
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Altec Lansing... • Answered on Oct 31, 2010
For what it would cost for the power cable, I would look for that same model on ebay, then you could have a spare set of speakers also.
Altec Lansing... • Answered on Oct 22, 2010
if it is happen for all the speaker then laptop fault dear.
Altec Lansing... • Answered on Jun 07, 2010
Please check your sound card device driver....
Altec Lansing... • Answered on Apr 02, 2010
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Altec Lansing... • Answered on Mar 10, 2010
i used the program restore on the computer.
Altec Lansing... • Answered on Oct 23, 2009
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Altec Lansing... • Answered on Jun 09, 2009
http://list.driverguide.com/list/company64/
Altec Lansing... • Answered on Apr 11, 2009
A constant low hum is a sign of a power supply issue. You need to check the capacitors that filter the ripple current and you need to check the diodes that convert ac to dc
Altec Lansing... • Answered on Feb 26, 2021
Could be a failing power supply
Altec Lansing... • Answered on Oct 29, 2020
Hi Michael, ask, have you allowed the battery to charge properly? Leave it plugged in, for the term of 12 hours, you would have to have a light that indicates charging status Then use it, until again it runs out of battery, again leave it 12 hours charging and should, work well Take the tests and comment If you can not make it work well, you should have the option to change the product, if it is new, in the store where you bought it I hope it works properly Greetings Franco Dosil https://fccid.io/2AE6GALP-XP850/User-Manual/user-manual-4144324.pdf
Altec Lansing... • Answered on Oct 05, 2020
Most likely be component failure on the circuit board. If so inclined, open the unit and see if there are burnt/discolored resistors. Hopefully you have a warranty and can have the unit replaced
Altec Lansing... • Answered on Sep 18, 2020
First, there is NO screen on the boom box. The issue is with whatever you have the speakers connected to.
Altec Lansing... • Answered on Apr 02, 2020
https://www.youtube.com/watch?v=RJOjRjX77x8
Altec Lansing... • Answered on Mar 28, 2020
Altec Lansing ADA 215 Computer Speakers Logo
20 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
need driver
  • Audio Players & Recorders
