20 Most Recent Altec Lansing AVS 300 Computer Speakers Questions & Answers
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Altec Lansing... | Answered on Jan 31, 2015
hello waiyasin, this altec lancing don't need a driver, it just plug and play hardware. if there is a problem with the driver, try to install sound driver from your motherboard driver. if u use external sound card, try to install sound driver from the sound card driver. if u have problem how to install the driver then u just need open the device manager. u can find it on control panel. once u open the device manager window, insert motherboard driver (or sound card driver if u use external driver) into CD Rom. in device manager window u will find sound or audio device, right click it and choose update driver then follow the instruction. that's it.
hope this useful, regards.
NB: if u don't have motherboard (or sound card driver) try to goggling it or reply this solution with your motherboard name (or sound card name), maybe i can help to find your driver.
Altec Lansing... | Answered on Aug 21, 2011
http://download.cnet.com/altec-lansing-multimedia-usb/3000-18493_4-87599.html
Altec Lansing Multimedia USB Speakers - ADA 305
hope this helps
Altec Lansing... | Answered on Aug 10, 2011
if the voltage and the polarity is the same, it will be fine. with amps, you want AT LEAST as many as the old adapter, or more.
more amps will not hurt, but more volts would hurt.
Altec Lansing... | Answered on Mar 19, 2011
Check if the sound card is correctly setup with drivers.
Do this by going to Control Panel, Device Manager and check on sound cards.
Can you hear sounds from regular laptop speakers??
If not, the problem is in the sound card, which is already integrated on the motherboard.
This makes it harder to fix, unless your laptop is under warranty.
If it is software related to the OS or conflict with other devices, you are more likely to fix it.
God Bless You!
Altec Lansing... | Answered on Feb 05, 2011
Hello there,
i have never seen a hard wired speaker need a driver, but with the right model number i am sure i could find a driver for it .
don't forget to Rate
Altec Lansing... | Answered on Jan 26, 2011
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Altec Lansing... | Answered on Jan 21, 2011
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s for this device
to do this right click on the ? x ! select reinstall driver
the drivers might have been corrupted by something or you might have got a virus run your antivrus program
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Altec Lansing... | Answered on Jan 09, 2011
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Altec Lansing... | Answered on Dec 11, 2010
Altec Lansing AVS 300 Computer Speakers Logo
38 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
altec lansing
  • Audio Players & Recorders
