20 Most Recent BenQ M310 Wireless Mini Optical Mouse Questions & Answers
2answers
My nephew gave me a benq 310 wireless mouse to try
Press on the front of the button on top and the battery cover ejects.
When you press the rear of the button it ejects the dongle.
3/28/2019 7:37:10 AM • BenQ M310... • Answered on Mar 28, 2019
0answers
How to pair
Be the first to answer 4/14/2014 4:01:42 AM • BenQ M310... • Posted on Apr 14, 2014Be the first to answer
2answers
Changing the batteries on the BenQ Wireless Mouse
If you slide down (hard) the panel beneath the 2 clicker keys, you will find a battery compartment with space for 2 AAA batteries7f60d17e-8b58-4076-acc1-563ab4428c0d.jpg
5/18/2013 3:57:15 AM • BenQ M310... • Answered on May 18, 2013
0answers
0answers
Have put new batteries in
If there any lights on the mouse when you put new batteries in the mouse? If yes then you can still fix it. On the usb controller of you mouse it will have a button on it. Press that button first and then press the button under the mouse. Repeat a few times and see if mouse responses. Then if nothing happens, unplug the usb controller and place it into another port. Repeat the above process and see what happens. Should work fine.
2/12/2011 2:51:31 PM • BenQ M310... • Answered on Feb 12, 2011
I cannot install my mouse on my comp because when
Some peripheral devices require you to run the installation software before you connect the device. Might that be the case here?
1/20/2011 5:04:57 AM • BenQ M310... • Answered on Jan 20, 2011
Hi there, Case A08 200092 I wrote asking a few
http://www.shopwiki.co.uk/Benq+M310+Wireless+Mini+Optical+Mouse+Red+USB
8/24/2010 10:18:01 AM • BenQ M310... • Answered on Aug 24, 2010
2answers
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
4/13/2010 8:42:55 AM • BenQ M310... • Answered on Apr 13, 2010
4answers
Problem pairing wireless mouse to reciever
HI ALL, Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is the process of coordinating your mouse's transmitter with your mouse's receiver. It requires both parts to operate on the same frequencies, usually by using the same identification code. Pairing takes place to try to eliminate interference. Some devices automatically pair both devices at start up; others need to be manually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteries in mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) and place the batteries. Cover, Now you can see the red light glowing on the bottom of the mouse, now your mouse is ready to pairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE will be ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, if mouse curser is not moving then press BUTTON 2 one time – now defiantly your mouse will work, If you need any other technical support for GMAX, products please contact
4/13/2010 8:29:07 AM • BenQ M310... • Answered on Apr 13, 2010
2answers
My wireless mouse will not work, I forget how to
1. Try unplugging usb device and replugging in (I'm sure you already did that) LOL
2. Uninstall device driver
3. After uninstall plug in USB device
see if that works
1/11/2010 2:20:28 PM • BenQ M310... • Answered on Jan 11, 2010
4answers
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
8/26/2009 7:03:43 PM • BenQ M310... • Answered on Aug 26, 2009
Not working
1/22/2009 11:11:44 PM • BenQ M310... • Answered on Jan 22, 2009
Setting up the mouse
go control panal aad/remove hardware scan the mouse drive automatically then restart
10/10/2007 5:38:15 AM • BenQ M310... • Answered on Oct 10, 2007
BenQ M310 Wireless Mini Optical Mouse Logo
31 questions posted
Top BenQ Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Marvin
Marvin
Paul Bade
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • BenQ Computers & Internet
Most Popular Question
changing batteries benq wireless mouse
  • Computers & Internet
