20 Most Recent Altec Lansing MX5021 Computer Speakers Questions & Answers
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Altec Lansing... | Answered on Oct 07, 2019
I have Altec Lancing Fx5051 5.1 No doubt the Sound Quality is Awesome however, I had some Issues with the Speakers and the Power.. While Playing the Device .. Suddenly the Sounds become so Low that it becomes Difficult for any one to Listen.. but again after some Adjustment is Volume.. the Sounds Come back ... and this Things had to be Repetead every 2-3 minutes .....
I had Called up the Service Center Guys .. they asked me to Change the Power Supply to another point and Try ... I did but nothing worked ...
Now that I have Changed my entire Home with New Electrical Wires and Earthing Properly Fixed ... the Problem Still Persists ... But Now I see that the main Woofer is Not taking Power ... I dont Know wot is wrong ... Can you Please help me ... ...
Altec Lansing... | Answered on Feb 15, 2018
Sounds like you might have a wire loose at the other side of the controller. This is a easy thing to find out. Just unscrew the side screws that hold the back board to the cabinet. Don't unscrew the screws connected to the speaker wire clips unless the back doesn't come off. Just look for a disconnected wire at the controller jack then put it back. If there is no loose wire then you might have a bent female contact at the outside of the controller jack. You would have to look for this looking into the holes where you plug the cable into the controller jack. If you see a bent contact then use a thin nail of ice pick and insert it into the hole where the bent connector is to try to re open the contact so the cable can slip into it easy. Don't forget to unplug the power first.
Altec Lansing... | Answered on Nov 08, 2013
bad signals
Altec Lansing... | Answered on May 26, 2013
They do fit but the hole in the speakers are very small so you have to apply a bit of force to screw them in.
Altec Lansing... | Answered on Dec 10, 2011
Altec Lansing MX5021 Computer Speakers Logo
48 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
altec lansing mx5021 wired controller
  • Audio Players & Recorders
