20 Most Recent Honda Piston Rings Snow Blower Lawn Mower Generator Questions & Answers
Refer to my other comments that I made regarding your snow blower.
Honda Piston... | Answered on Dec 06, 2013
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
you may have a faulty actuator that governs it for you need to check if coil of actuator is excited with power when you draw current
Honda Electrical... | Answered on Aug 23, 2020
yes this load sensor module has a coil that is wrapped on a single line of stator output.this board may utilize a 12 volt source from alternator
Honda Electrical... | Answered on Aug 22, 2020
Maybe you can ask your supplier to get the wiring diagram
Honda Electrical... | Answered on Jan 06, 2020
Check oil alert switch, ignition switch and connections.
Honda Electrical... | Answered on Dec 30, 2019
Honda generator? Please ask your supplier for the answer. They can help you.
Diesel generator set problem support: www.dieselgeneratortech.com
Honda Electrical... | Answered on Dec 04, 2019
If you need more support, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 15, 2019
If you need more support, please visit www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 10, 2019
For your question, i have replied many people, why generator set can start but not generate electricity?
Here is some reasons for reference:
1.After the diesel generator is stopped, the residual magnetism is often lost, because the material used for the magnetic pole of the exciter is close to the soft steel, and the residual magnetism is small. After the shutdown, when there is no current in the excitation winding, the magnetic field will disappear.
2.The magnetic pole of the diesel generator loses its magnetic properties.
3.Damage of excitation circuit components or circuit breakage, short circuit or grounding phenomena.
4.The exciter brush is not in good contact with the commutator and pressure of brush holder is insufficient.
5.Excitation winding wiring error, opposite polarity.
6.Stator winding and rotor winding of generator set open circuit.
7.Poor contact between diesel generator brush and slip ring, or insufficient brush pressure.
8.Diesel generator lead wire wiring is loose or switch contact is poor.
9.The fuse box is fused.
10.The "auto-manual-de-excitation" switch on the control panel is in the de-excitation position (automatic generator set has "auto-manual-de-excitation" switch).
11.The voltmeter is damaged.
12.Rotary rectifier module is damaged.
Honda Electrical... | Answered on Oct 09, 2019
Most of the time it is either the Capacitor or AVR that has blown (depending on what is fitted on your generator.). Check out our videos on how to test them.
We hold a full range of Generator AVRs and Capacitors. https://www.generatorguru.com
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Honda Electrical... | Answered on Aug 19, 2019
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Honda Electrical... | Answered on Jul 27, 2019
you probably have either a bad capacitor or more likely a short stator winding due to previous overloading
Honda Electrical... | Answered on Jun 03, 2019
Verify that the double gang circuit breaker is good on both sides. Check for loose wire on breaker or receptacle.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Honda Electrical... | Answered on May 31, 2019
use your car battery and jump it. you cannot get too big a battery. big is better.
Honda Electrical... | Answered on Apr 10, 2019
If it's on a Ryobi Generator then it should be a real Honda Engine. It's possible that it's a knock off or was replaced with one. If you bought it new from a reputable source then it's real, if it's used or came from an offshore source for a really low price then it's a good possibility that it's a kkoxk off. In all honesty, from my experience they do a great job with the knock off engines & they're usually reliable and last a normal life span similar to a real name brand.
Either way, that mechanical Issue Remains, I'm assuming you're refering to the valve being stuck and basically keeping the engine locked up and not allowing it to the over when attempting to start it. Sounds likely. Did you take the spark plug out and turn it over to see if it'll turn over at all to ensure it's not just totally locked up? My suggestion would be to Remove the valve cover and spark plug so that you can see the valvetrain in action when(if so) it is turning over and observe it to see if your valve theory is correct!
Thanks and good luck my friend, see the infinity below please, have a great day!
Honda Electrical... | Answered on Mar 18, 2019
Honda Piston Rings Snow Blower Lawn Mower Generator Logo
3 questions posted
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
honda hs55 when handle depressed blower
  • Electrical Supplies
