20 Most Recent Honda Eb 3500 Generator Questions & Answers
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
Honda Eb 3500... | Answered on Dec 18, 2014
First check you engine's rpm. Your generator is a 60 hz unit it need to be 3600-3750rpm; if 50 hz then it need to be 3000-3100.
If voltage is still down and the rpms are correct then alternator's voltage regulation circuit needs checking. To do this you need to have make and model posted.
Honda Eb 3500... | Answered on Dec 17, 2014
The error code is for incorrect air/fuel ratio. The first thing to try and most common cause is a bad fuel filter. Try replacing the fuel filter. It is possible that the 2 cycle mix, since it contains oil, had gummed up the filter. I would also run some carburetor cleaner through it.
Honda Electrical... | Answered on Nov 27, 2020
you may have a faulty actuator that governs it for you need to check if coil of actuator is excited with power when you draw current
Honda Electrical... | Answered on Aug 23, 2020
yes this load sensor module has a coil that is wrapped on a single line of stator output.this board may utilize a 12 volt source from alternator
Honda Electrical... | Answered on Aug 22, 2020
Maybe you can ask your supplier to get the wiring diagram
Honda Electrical... | Answered on Jan 06, 2020
Check oil alert switch, ignition switch and connections.
Honda Electrical... | Answered on Dec 30, 2019
Honda Eb 3500 Generator Logo
Popular Tags
21 questions posted
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
honda eb3500x shuts off when auto
  • Electrical Supplies
