20 Most Recent Canon SmartBase MP730 All-In-One InkJet Printer Questions & Answers
Hello Mike,
Please try to refill the catridge and if it dint help you then replace the Catridge ,which will surely pay off you..Thank you...
Please Post on how things turned or for further assistance..!!
Regards!!...
Canon SmartBase... | Answered on Apr 22, 2020
Difficult to be certain with the information given; but, it may be that you have updated your operating system to a point where the original scanner software is no longer the correct version for your operating system. If you have not already done so, try downloading the latest driver and software from the canon website and install that.
Canon SmartBase... | Answered on May 07, 2017
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Canon SmartBase... | Answered on Sep 05, 2011
Bonjour g_zeine
Tu peux y arriver en t?l?chargeant printfab : http://www.printfab.net/ mais ce n' est pas gratuit .
Cordialement ,
fanaudi .
Canon SmartBase... | Answered on May 22, 2011
Try replacing all the ink absorbers and resetting the counter to zero.
Canon SmartBase... | Answered on Mar 27, 2011
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Canon SmartBase... | Answered on Jan 20, 2011
You can download required driver by searching with model no with google
Canon SmartBase... | Answered on Jan 16, 2011
Here are the codes for your cartridges: BCI-3eBk (Black), BCI-3eY (Yellow), BCI-3eC (Cyan), BCI-3eM (Magenta)
Canon SmartBase... | Answered on Dec 28, 2010
Here is the procedure for resetting waste ink message
  • Hit the "menu": Key
  • Hit "Copy" Key
  • Hit "#" Key
  • Scroll thru the menu headings until you come to "Test Mode" - 12th heading
  • Hit the "3? button- this will bring up Eeprom Clear
  • Hit "0? button
  • Hit the "Stop" button
Canon SmartBase... | Answered on Oct 18, 2010
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Canon SmartBase... | Answered on Mar 23, 2010
Hi there
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Canon SmartBase... | Answered on Feb 26, 2010
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Canon SmartBase... | Answered on Feb 11, 2010
2. Hit "Copy" Key
3. Hit "#" Key
6. Hit "0" button
Canon SmartBase MP730 All-In-One InkJet Printer Logo
Popular Tags
57 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error 334 its problem
  • Office Equipment & Supplies
