20 Most Recent Honda Alternator Crv 1999 99 2000 00 2001 01 Auto Questions & Answers
2answers
Fuel problem with crv 1999 model?
Are you sure it's fuel?, it won't start w a shot of ether?or it will? More often than not?, the distributor is the culprit, thanks
5/17/2016 6:17:07 AM • Honda Alternator... • Answered on May 17, 2016
REPLACE MOTOR MOUNTS
move to service center
6/11/2014 11:49:17 AM • Honda Alternator... • Answered on Jun 11, 2014
I have a 2001 CRV. The replacement alternator has 4 prong plug. The one on the car has a green 3 prong plug?
Here's the problem:http://honda-tech.com/showthread.php?t=2624894Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.Don't know where you live or where you bought the vehicle but it's Canadian. Next time you need parts be sure and tell your supplier that it needs Canadian parts.
10/8/2012 3:56:01 AM • Honda Alternator... • Answered on Oct 08, 2012
Have no output power on my pramac s5000 . Motor starts fine, flip CBS on, and motor surges a second.
Disconnect all loads before turning on breaker. Add one load at a time. Do not exceed generator capacity.
Comment below for further assistance.
6/18/2021 3:48:57 PM • Honda Electrical... • Answered on Jun 18, 2021
Honda generator EU65is. The overload indicator light will not shut off. Why?
It would normally show that you are drawing more power than the generator can supply. Videos in the link https://www.google.com/search?q=Honda+generator+EU65is+overload+indicator ..
4/18/2021 9:49:42 PM • Honda Electrical... • Answered on Apr 18, 2021
3answers
I have a gas generator a Honda and someone put 2cycle feul in it now it starts and runs for 20 to 30 minutes and. Stops it displays trouble code E-0A
The error code is for incorrect air/fuel ratio. The first thing to try and most common cause is a bad fuel filter. Try replacing the fuel filter. It is possible that the 2 cycle mix, since it contains oil, had gummed up the filter. I would also run some carburetor cleaner through it.
11/27/2020 10:56:34 AM • Honda Electrical... • Answered on Nov 27, 2020
2answers
Why wont my governor pull in when my Honda ex1000 is under load?
you may have a faulty actuator that governs it for you need to check if coil of actuator is excited with power when you draw current
8/23/2020 12:40:18 PM • Honda Electrical... • Answered on Aug 23, 2020
Honda generator GX270 idles but won't speed up under load
yes this load sensor module has a coil that is wrapped on a single line of stator output.this board may utilize a 12 volt source from alternator
8/22/2020 3:32:40 AM • Honda Electrical... • Answered on Aug 22, 2020
Require a wiring diagram for a honda copy 7.5kva diesel generator, please
Maybe you can ask your supplier to get the wiring diagram
1/6/2020 2:35:31 AM • Honda Electrical... • Answered on Jan 06, 2020
No Spark On Ems 4500 Honda Generator
Check oil alert switch, ignition switch and connections.
12/30/2019 3:36:50 AM • Honda Electrical... • Answered on Dec 30, 2019
2answers
I have a EB3500 honda generator that trips the AC circuit breaker when there is no load on it. What could it be?
Honda generator? Please ask your supplier for the answer. They can help you. Diesel generator set problem support: www.dieselgeneratortech.com
12/4/2019 12:48:41 PM • Honda Electrical... • Answered on Dec 04, 2019
Honda 8750 blackmax no electricity
If you need more support, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com
10/15/2019 3:12:19 AM • Honda Electrical... • Answered on Oct 15, 2019
Honda em 600 generator puts out to much voltage
If you need more support, please visit www.dieselgeneratortech.com
10/10/2019 2:18:43 AM • Honda Electrical... • Answered on Oct 10, 2019
HONDA EM650 Generator starts but wont power anything up
For your question, i have replied many people, why generator set can start but not generate electricity? Here is some reasons for reference: 1.After the diesel generator is stopped, the residual magnetism is often lost, because the material used for the magnetic pole of the exciter is close to the soft steel, and the residual magnetism is small. After the shutdown, when there is no current in the excitation winding, the magnetic field will disappear. 2.The magnetic pole of the diesel generator loses its magnetic properties. 3.Damage of excitation circuit components or circuit breakage, short circuit or grounding phenomena. 4.The exciter brush is not in good contact with the commutator and pressure of brush holder is insufficient. 5.Excitation winding wiring error, opposite polarity. 6.Stator winding and rotor winding of generator set open circuit. 7.Poor contact between diesel generator brush and slip ring, or insufficient brush pressure. 8.Diesel generator lead wire wiring is loose or switch contact is poor. 9.The fuse box is fused. 10.The "auto-manual-de-excitation" switch on the control panel is in the de-excitation position (automatic generator set has "auto-manual-de-excitation" switch). 11.The voltmeter is damaged. 12.Rotary rectifier module is damaged.
10/9/2019 3:31:47 AM • Honda Electrical... • Answered on Oct 09, 2019
MY BLACKMAX 7000/8750 RUNS GOOD BUT THERE IS NO ELECTRICITY GENERATING, HOW DO I FIX THIS?
Most of the time it is either the Capacitor or AVR that has blown (depending on what is fitted on your generator.). Check out our videos on how to test them. We hold a full range of Generator AVRs and Capacitors. https://www.generatorguru.com We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/ Parts Spares for Generators and Small Engine Machinery image-2fwsrbehqcya13uxwt41l5dc-5-0_4.jpg
8/19/2019 11:11:05 AM • Honda Electrical... • Answered on Aug 19, 2019
3answers
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
7/27/2019 9:54:42 PM • Honda Electrical... • Answered on Jul 27, 2019
Honda eg 550 generator starts but if i conect the plug from astatior the motor labour
you probably have either a bad capacitor or more likely a short stator winding due to previous overloading
6/3/2019 9:38:15 PM • Honda Electrical... • Answered on Jun 03, 2019
Hi guys i have a Honda GX 160 petrol generator that is only producing on the 110 volt socket, 220 volt does not produce
Verify that the double gang circuit breaker is good on both sides. Check for loose wire on breaker or receptacle.
6/3/2019 3:45:09 PM • Honda Electrical... • Answered on Jun 03, 2019
Honda Alternator Crv 1999 99 2000 00 2001 01 Auto Logo
9 questions posted
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
john h
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
fuel problem crv 1999 model
  • Electrical Supplies
