20 Most Recent Canon S 330 Photo InkJet Printer Questions & Answers
I had the same problem. It turned out my printer was set to print on the "Canon Fax" printer rather than the regular Canon printer. So I changed the printer on the print box screen and was able to print as usual.
Canon S Office... | Answered on May 24, 2014
Hi Jonatas Bila, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Canon S Office... | Answered on Dec 14, 2013
Internal battery needs replacement
Canon S Office... | Answered on Oct 20, 2013
Code d'erreur Canon IR2420L E000100-0000 Comment r?soudre s'il vous pla?t
Il y a 4 minutes · Mat?riel et fournitures de bureau Canon · 0 r?ponse
Canon Office... | Answered 3 days ago
Something similar to this:
1. In standby mode,press the "Settings/Registration" key.
2. Press the"Reset" key.
3. Press the"Back" key.
4. Press the"Settings / Registration" key.
5. The service modescreen is displayed.
6. Scroll to Printerthen choose Clear
Use the"Back" key to exit Service Mode
Canon Office... | Answered on Oct 20, 2020
I would check to that you have the newest print driver installed.
Canon Office... | Answered on Oct 16, 2020
  • Check just inside the Canon printer for any paper jam and any obstruction if there.
  • The next thing is to ensure that ink tanks are inserted correctly into your printer.
  • Finally, all users are requested to unplug the power cord from the back side of the printer for at least 20-30 seconds.
  • Plug in the power cord after waiting and turn the printer back on.
  • Your printer needs to be replaced if these steps do not solve your issue.
Canon Office... | Answered on Oct 11, 2020
Easy Process To Remove Canon Error Code 751
Try out the solutions given below and check if the steps are efficient enough to resolve Canon error 751 successfully.
Process 1: Server Settings
Check the status of the server first. It shows an offline state, turn it on immediately. Moreover, make sure that the network is fair. Now, verify the Canon printer is functioning or not.
Process 2: Reset TCP/IP Settings
To open the "Settings" window, tap the "Start" button and select the "Settings" option. After that, open the Network & Internet Properties window by selecting the Settings Window option, "Network & Internet."
You'll get the type of connection here. If the Wired cable is used, select "Ethernet." Now select the "Check Adapter option" option, and you're going to get a different window. Then select the "Ethernet" type of network and right-click it. A pop-up menu will then appear and the "Properties" option is selected to check the status of TCP / IP.
Finally, check whether the type of protocol is correctly selected or not. Otherwise, as per your system requirement, you can select IPV4/IPV6 and press "OK" button to proceed further.
Process 3: Remove Multiple Copies
First, remove all copies from the system tray queue. Now, by keeping the first one in the system tray and stop browsing, cancel the rest of the documents. Now scan the document and send it one by one to the rest of the files. It will remove the SMB error and, like major conflict, remove the network jam.
However, if you don't get a perfect solution for the 751 error code, you can contact us for immediate support.
Canon Office... | Answered on Oct 06, 2020
Go to canon's we site check for updates.
Canon Office... | Answered on Sep 15, 2020
In canon printers the most common error code is B200. You'll learn in this article how to resolve canon printer error b200 by self.
The Canon Printer Error Code B200 on the canon printers means that the voltage of the print head or the heat of the printhead is not usual. In certain situations, the b200 error can also result in damage to the print head and being unable to use it, or a problem with the cartridges.
The Canon printers come in two or 4 + cartridges. If you have Four or more cartridges on your printer, you need to follow the instructions below. If you have a two-cartridge printer, skip to the section below.
Step 1: Extract all cartridges.
Step 2: Extract the printhead.
Step 3: The print head is reinstalled.
Step 4: Bring the cartridges back in.
Step 5: Continue Blog - Canon Printer Error B200
Canon S 330 Photo InkJet Printer Logo
0 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
S Canon
  • S Canon
Most Popular Question
system error e197 displayed canon ir1018
  • Office Equipment & Supplies
