20 Most Recent Canon BJ I6500 InkJet Printer Questions & Answers
Search Fixya...canon i6500
Do you have a question about this printer?
7/11/2013 3:34:34 PM • Canon BJ I6500... • Answered on Jul 11, 2013
2answers
My Canon i6500 Printer has been in storage for a
There is a mains power lead needed for this model of printer.
I don't have the same model printer here with me, but as far as I know from this range, you will need a standard *figure-8* lead, available from most shops around. Many £1 shops have them too.
6/13/2013 5:18:27 AM • Canon BJ I6500... • Answered on Jun 13, 2013
0answers
2answers
When i turn the printer on the light flashes amber
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
4/20/2013 4:30:20 AM • Canon BJ I6500... • Answered on Apr 20, 2013
Why does my canon i6500 suddenly stop printing
Have you checked out the color print cartridge? I guess the ink is finished. Try get a new ink.
peace.
2/26/2011 5:40:48 PM • Canon BJ I6500... • Answered on Feb 26, 2011
Mijn A3 printer, de i6500,
please write in English
1/12/2011 10:31:05 AM • Canon BJ I6500... • Answered on Jan 12, 2011
How to clean print head
Print heads can be cleaned by using the commercially available print head cleaners or you can use warm-hot water. Gently clean the print heads with soft, lint-free cloth as the heads are very fragile and may get damaged. Dipping the printheads in hot water would dissolve dried-up in stuck in the heads.
Good Luck!
Hope this helps!
CreativeTECH
12/14/2010 6:59:56 AM • Canon BJ I6500... • Answered on Dec 14, 2010
0answers
The yellow and blue ink doesn't seem to be
Hi Marie As this printer is now getting on a bit it could be that the print head is worn out. I had to replace mine a year or so back and now it prints as it didwhen new.
Print heads are not exactly cheap, but they're a cheaper than a new A3 printer.
7/17/2010 1:45:00 AM • Canon BJ I6500... • Answered on Jul 17, 2010
My Canon i6500 can not print in black? Is there is
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
5/9/2010 10:59:10 AM • Canon BJ I6500... • Answered on May 09, 2010
Printed photo's are pale and seem washed out. Is
Go to "start menu", then "settings", then "Printers and faxes". Open Printers and faxes. Right click on your printer. You will see a menu. Find "properties". A menu will open (usually, the first thing you see is "General"). On the bottom, you will see "printing preferences". Click on that. A window will open. It has two tabs: one is "layout", the other is "paper/quality". Look at the layout menu, you will see on the bottom a button named "advanced". Click on it. Find "document options". Click on the + next to it. On the bottom, you should see "printer features" and underneath it "print quality". Try changing the print quality to "high quality". That should improve the quality of your pictures.
4/1/2010 8:19:21 AM • Canon BJ I6500... • Answered on Apr 01, 2010
We have just changed the black printer cartridge
Ok are you sure that you have it set to Black & White, or Greyscale? Also ensure that you do a head clean, too. Give the cartridge a good shake up to mix up the ink. If it is purple, make sure that,that isn't the color of the "Font" that is printing... unlikely but just a thought.
3/30/2010 12:50:54 AM • Canon BJ I6500... • Answered on Mar 30, 2010
Error code 5C00 on canon printer i6500
driver reinslled
1/12/2010 9:20:50 AM • Canon BJ I6500... • Answered on Jan 12, 2010
My canon i6500 is missing line and washed out when printing.
This sounds like you are using either refilled cartridges or after market cartridges and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice, alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
10/7/2009 1:51:43 AM • Canon BJ I6500... • Answered on Oct 07, 2009
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
10/7/2009 1:47:53 AM • Canon BJ I6500... • Answered on Oct 07, 2009
The printer
check the ink nozzels it may got ink clogging.
use distel water and one serenze, take out ink tanks and inject the distel water by force, it may open ink nozzels.
then put back ink tanks and from driver do ink charging it will take 1-2 mins then use ur printer normally
8/20/2009 8:08:07 AM • Canon BJ I6500... • Answered on Aug 20, 2009
Canon BJ I6500 InkJet Printer Logo
31 questions posted
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
when turn printer light flashes amber
  • Office Equipment & Supplies
