20 Most Recent Canon S 330 InkJet Printer Questions & Answers
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Canon S 330... | Answered on Feb 26, 2010
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Canon S 330... | Answered on Jul 28, 2008
You Might Need A New Printer Head It Will Be Less Than $35 Shipped Just Call Customer Service / Parts Dept.
Canon S 330... | Answered on May 30, 2008
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Canon S 330... | Answered on Jan 03, 2008
I had the same problem. It turned out my printer was set to print on the "Canon Fax" printer rather than the regular Canon printer. So I changed the printer on the print box screen and was able to print as usual.
Canon S Office... | Answered on May 24, 2014
Hi Jonatas Bila, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Canon S Office... | Answered on Dec 14, 2013
Internal battery needs replacement
Canon S Office... | Answered on Oct 20, 2013
First, try launching the scan software from your PC. This requires you to install the full driver and software package (from the CD or https://www.usa.canon.com/internet/portal/us/home/support/details/printers/inkjet-multifunction/mg-series-inkjet/mg7520/pixma-mg7520?cm_sp=CSO-_-PFListing-_-MG7520 ). Initiate a scan from the computer to find the settings that work best for your usual documents. Note: the full software needs to be installed before you connect the all-in-one to the computer if you use the USB port.
Next, make sure that the scan monitor program is running. For Windows, there are two programs involved the Canon Scan Gear (driver) and the Canon IJ Scan Utility. For the all-in-one on the network, it's the IJ Scan Utility EX. (The program names may be different under the Mac OS.)
It's the IJ Scan Utility that you need to use to set the response from the buttons on the MG7520. Launch the utility and click on the Settings button (bottom right). Click on the Operations icon (the box with the arrow pointing out towards you). Set the default settings for each of the scan buttons (Save to PC (Auto), Save to PC (Photo), etc.) You need to set the folder to save the information and resolution. You can also set the software that you want to use to manipulate scanned data if you plan to crop the image or deal with a skewed image. Click OK to save the settings.
Now, you should be able to use the Operation panel buttons to launch a scan when IJ Scan Utility is running.
I hope this helps. Screen captures of the IJ Scan Utility Settings page are available in the manual. See the section starting on page 793 of the PDF. The PDF and an EXE file with the manual available here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/inkjet-multifunction/mg-series-inkjet/mg7520/pixma-mg7520?tab=manuals .
Canon Office... | Answered 3 hours ago
Canon S 330 InkJet Printer Logo
Popular Tags
11 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
S Canon
  • S Canon
Most Popular Question
find paper thickness lever canon s330
  • Office Equipment & Supplies
