20 Most Recent
Canon imageCLASS MF5730 All-In-One Laser Printer Questions & Answers
Fax won't transmit or receive
you need to flush the memory of the fax in the settings, some faxes machines depending on the grade or type can hold between a few MB up to 64 MB or more with expansions. Corporate photocopiers or bigger machines have an internal hard drive to store the data.
Just go through the settings and look for something that will let you empty the logs of the faxes that were received and send.
Also most of the all-in-one machines have a web interface if they support Ethernet (network) connection where you can perform those task in a more easier manner.
Have canon mf5700 says check paper size and only prints one page of several page job
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
I don't know how to scan
Think that you understand. To your dictation manual
http://files.mail.ru/KDLYOZ
here instructions on installations and maintance manual on repair, mistake and use. Uachi you.
Byloby not bad if have noted my facilities on FIXya
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
