20 Most Recent Sunpentown IM-150US Undercounter Ice Maker NEW Questions & Answers
I don't know of any 'push rose', on an internal combustion engine. Ah, you mean 'push rods' perhaps, the things that open the valves? The push rod is just a steel rod that works on a cam and presses the rocker, which presses the valve stem tip. Hopefully they just need adjusting, if not, it is a catastrophic failure!
https://www.lifanpowerusa.com/product-category/generators/energy-storm-series/
Electrical... | Answered on Jul 12, 2020
top of your electrical panel
Electrical... | Answered on Jul 10, 2020
output depends on what loads you draw on any genset
Electrical... | Answered on Jun 30, 2020
power to starter have never seen one to know if they have a solenoid for it or not
Electrical... | Answered on Jun 29, 2020
you have carb passages that are still clogged up. when you do get it all clean and running always use a little seafoam in your fuel. it works very well on small engined units... a few ozs in 5 gallons is plenty and stores very well also.
Electrical... | Answered on Jun 12, 2020
check the operation of the oil level sensor . No oil no start
Electrical... | Answered on Jun 08, 2020
From what I see on other disposals, the hex is in the middle of the bottom. Remove the paper tag.
https://www.youtube.com/watch?v=J0OByRuoYM0
Electrical... | Answered on Jun 06, 2020
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Electrical... | Answered on Jun 03, 2020
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions.
www.dieselgeneratortech.com
Electrical... | Answered on May 29, 2020
Exhaust black smoke
The main causes of exhaust pipe blackening are less air in the cylinder, more fuel, incomplete or untimely combustion of fuel. Therefore, when checking and analyzing faults, look closely around this point to find out reasons. Check cylinder by using the method of oil cut, the first distinction is that the individual cylinder is not working well or all cylinders are not working well. If the black smoke disappears when a cylinder stops working, then the black smoke is caused by the bad work of individual cylinders. The reasons can be found from the bad work of individual cylinders.
The main reasons are:
A. Poor nozzle operation
The injection pressure of the injector is too low, the nozzle drips oil, the spray quality is not good and the oil droplet is too strong, all of which will cause the diesel fuel to burn incompletely. Therefore, in the detection of diesel engine cylinder knocking sound, exhaust sound uneven, that is, fuel injection problems, should be immediately checked and adjusted injection nozzle.
B. The fuel injection pump adjusts the tooth rod or the adjustment rod stroke is too large, resulting in too much fuel supply.
C. Valve clearance does not meet requirements, resulting in insufficient air intake.
D. The contact surface between the plunger sleeve of the injection pump and the valve seat is not sealed, or the locking screw of the regulating ring of the fuel injection pump or the loosening of the plunger adjusting arm cause the imbalance of the fuel supply and lead to intermittent black smoke emission.
More supports, please see on www.dieselgeneratortech.com
Do normal maintenance first, like oil, oil filter and air filter and then let it firts warm up before applying a load.
You have posed a very vague question with no details about the application and have even omitted to tell us whether you have a generator set or whether you have the alternator and wish to build your own generator set?
In the case of a generator set the requirements and precautions will be found in the owner's instruction handbook.
Sunpentown IM-150US Undercounter Ice Maker NEW Logo
2 questions posted
Top Sunpentown Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sunpentown Electrical Supplies
Most Popular Question
off switch generator not working
  • Electrical Supplies
