20 Most Recent Honda Generator Eb4000x Eb5000x Eb6500x Spark Plug - Ngk Bpr5es Questions & Answers
I have a Honda 6.5kva generator, Its new, only 20
take it in to honda dealer for a warranty check
8/25/2017 5:30:31 AM • Honda Generator... • Answered on Aug 25, 2017
EB5000X SUT OFF WHEN HOT WILLNOT START NO SPARK UNTILL COOLS DOWN
CHECK YOUR OIL LEVEL
7/12/2014 1:01:30 AM • Honda Generator... • Answered on Jul 12, 2014
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
8/12/2012 6:29:28 PM • Honda Generator... • Answered on Aug 12, 2012
Honda gas compressor ec2510e runs great but when reaches 120psi the gas engine idels and the control lever keeps moving back and forth by itself
Your compressor is made by Hitachi. The pilot valve is what controls the engine and the pressure. Most likely the pilot is set to idle engine at 125 psi. The pilot valve can be adjusted higher or lower depending on needs but not higher than say 140. As the pressure drops to about 80 psi the pilot will cut in the engine to refill the tank. Pilot and throttle controls are finicky and require constant tinkering and or parts replacement. Your compressor needs the pilot to control pressure however does not need the throttle control. You can set the engine on constant speed. Less trouble but uses little more gas. Just remove the throttle control from the pilot and plug the hole. If the bad part is the pilot itself you will need to replace it. The new pilot will be adjusted to about 125 psi. Good luck with your repair
8/27/2019 6:10:14 PM • Honda Air Tools... • Answered on Aug 27, 2019
Honda 5.5 air compresser will only starg on full
I'd re-clean the carb.
1/18/2018 2:21:50 PM • Honda Air Tools... • Answered on Jan 18, 2018
Oil Level Sensor Issues
Not worth the work. Just leave it disconnected and check oil twice daily under hard working conditions. Change the oil every 100 hrs of hard use or when it looks black and dirty.
4/17/2014 6:55:25 PM • Honda Air Tools... • Answered on Apr 17, 2014
0answers
0answers
Hose builds pressure and then will not spray
Hi
Look at all associated couplings on the delivery side of the receiver to ensure that air passing through
every joint/coupling and that the hose has not got collapsed walls that are compounded by air pressure.
A good tester to make up is to get 2 hose joiner ends, fit to an either a galv.or brass nipple, join together and test that there is a good flow of air from all points of delivery
Hope this helps
Cheers
John
7/22/2011 9:06:50 AM • Honda Air Tools... • Answered on Jul 22, 2011
I have a gx 160 5.5 honda rol-air compressor n
then that means the regulator is working.
5/21/2011 7:13:15 AM • Honda Air Tools... • Answered on May 21, 2011
My air compressor starts right
It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
Bruce
3/31/2011 6:46:08 AM • Honda Air Tools... • Answered on Mar 31, 2011
Honda Generator Eb4000x Eb5000x Eb6500x Spark Plug - Ngk Bpr5es Logo
8 questions posted
Top Honda Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Air Tools & Compressors
Most Popular Question
honda 6 5kva generator its new only 20
  • Air Tools & Compressors
