20 Most Recent Stanley Bostitch Gfn1564k 15-guage Cordless Angled Fn Finish Nailer Questions & Answers
Bostitch GFN1564K cordless nailer brand new wont fire.
take it back to the supplier for a replacement or warranty fix however as it is electric there may be a safety switch that you have to engage to make it work as it would go off when ever and spray nails and staples every where.
6/28/2015 12:05:50 AM • Stanley Bostitch... • Answered on Jun 28, 2015
2answers
My Stanley spot light comes on when I pull the trigger but goes right off soon has I let go
There are lots of models. Some have a trigger lock and some have a 5 position trigger. https://www.google.com/search?q=stanley+spotlight+manual ..
12/6/2021 11:31:46 PM • Stanley Air... • Answered on Dec 06, 2021
The trip cover of my Stanley Bostitch N60FN nailing gun keeps popping open. I’m using 15 gauge 2 1/2” angled Bostitch nails, and have adjusted my compressor between 80 and 100 psi, but it continues.
This can be caused by a couple of things: - Material is too hard and causing the nail to stress - Nails are too long causing the same thing - End of driver is worn or chipped causing the driver to ride over the nail and pop the nose open.
3/3/2021 2:26:24 PM • Stanley Air... • Answered on Mar 03, 2021
2answers
My Bostitch N12 won't advance nails
It could be the o-rings for the feed piston but a bad feed spring will also cause problems. that would be the easiest place to try if you can find a spring. Many of the parts for these are becoming NLA (no longer available) from Bostitch. One problem they had in the feed piston area was chipping the nose where the orign seals the piston stem. There is a small bumper on the inside of the feed piston cap that goes bad and allows the piston to travel to far back which slams the feeder against the lower housing and can chip it where the piston goes through.
11/6/2020 6:52:47 PM • Stanley Air... • Answered on Nov 06, 2020
Have a stanley air compressor worked fine but now the air won't come through the tip of the hose even when I put it on the tire?
Talking in the past tense about compressor working fine before. Is it working fine now" If it is, pumping the air tank full, and air not coming from the end of the hose, the end tool valve maybe jammed, or the hose plugged. (sometimes the inner lining of the hose separates from the reinforcing mesh and clogs the hose) To test this theory, take the hose off from the tank (when no air is in the tank), start the compressor and see if the air is pumping out freely. If it is then the compressor is indeed fine. Take the tool of the end of the hose, then reconnect the hose and restart the compressor. This will tel you if either the hose or the end tool is at fault.
11/25/2018 11:35:48 AM • Stanley Air... • Answered on Nov 25, 2018
Knob for a Stanley model 675919
Hello, Sean - I hope I am safe to assume you need to find a replacement knob for a Stanley brand Pro-Ceramic Utility Heater with Pivot Power Model 675919. If so, I refer you to Lasko, the company which manufactures that heater under the Stanley brand name. This is the number to call the Lasko Parts and Accessories Customer Service Department to find out if they supply (sell) replacement knobs for your unit: 800-233-0268 (Monday - Friday, 8am-5pm, Eastern Time zone) Best wishes
12/18/2017 10:04:18 PM • Stanley Air... • Answered on Dec 18, 2017
2answers
Stanley STFP00020 won't deliver air at the output even though it has tank under pressure
Try to remove the hose, then see if air comes out when you switch it on.
11/19/2017 3:00:41 AM • Stanley Air... • Answered on Nov 19, 2017
My Stanley compressor lost power. I replace the fuse inside but the motor keeps shorting out. Co. It might be the brushes but I can't get into the motor
check for a failed start/run capacitor otherwise take the motor to a repair shop or get a new motor
11/17/2017 9:19:18 AM • Stanley Air... • Answered on Nov 17, 2017
I got a new Stanley fat max power station for Christmas, today went to air up a tire (first time ever used) compressor runs great but air will not come out of nozzle. What can I do besides cry?
read the user manual to see what has to be done to pump air you may have to put it on the tire stem to depress the valve in the hose and the stem
7/17/2017 3:10:05 AM • Stanley Air... • Answered on Jul 17, 2017
Stanley Fat Max Power Station air compressor runs but no air. How to fix?
replace the poppet/reed vallves in the head/s
4/10/2017 1:13:51 AM • Stanley Air... • Answered on Apr 10, 2017
0answers
Stanley Bostitch Gfn1564k 15-guage Cordless Angled Fn Finish Nailer Logo
3 questions posted
Top Stanley Air Tools & Compressors Experts
john h
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Air Tools & Compressors
Most Popular Question
bostitch gfn1564k cordless nailer brand
  • Air Tools & Compressors
