20 Most Recent
Makita Bo5041k 5" Inch Random Orbit Sander Sanding Tool Kit Questions & Answers
Makita orbital sander does not orbit with new pad
there is bit more to the pad than just attachment surface, please have look at this page:
http://www.ereplacementparts.com/makita-bo5041-random-orbit-sander-parts-c-97_103_119063.html
your description suggest that there is no connection between pad and clutch, i would recommend to study the drawing, dismantle machine again and put it together again. where appropriate, use grease (i would suggest use of ptfe (teflon) dry spray grease on all moving surfaces and bearings), after service, use lowest possible settings, (disconnect filter! it is useless - use external vacuum if possible, connect to the pipe where filter was attached.) increase settings every minute or so till you have maximum.
lower the settings to your operational requirement and use as usual.
hope this will help you solve thsi little problem, if you find this answer helpful - do not forget to say so...
Why does my new Makita dbn600 brad gun will not go deep enough with the rubber protector on.
Makita and Dewalt can being used with similar nails of other brands ? some sellers will you do believe but i can say by marketing technical updates Makita and Dewalt have very rare strict tolerance on dimensions but only original nails will and must working without problems , and 2nd choice nails have allways an other thickness or other kind of bonding they are made of. , use only the nails of the brand you working with if you have or MAKITA or DEWALT use the nails for the brand. otherwise the nailbrads will not slide smoothly its very critical made the last years more and more models of the brand have restrictions and get very fast troubles with cheap homebrands of hardware store parties. USE ONLY ORIGINAL delivered by the new Makita and Dewalt tools. otherwise if not working read the user manual if no succes go for warranty if its not work correct .
Bostich n66 nailer
Does the nailer fire but just not drive a nail, or does it not fire at all? If it's the first situation, it's a magazine feed issue. I had one of those and it started doing something very similar. The magazine spring had gotten dirty from use which didn't allow it to function properly. (Carefully) disassemble the magazine and clean the spring. Automotive brake cleaner works pretty good for that. Spray the guides with a dry lubricant then reassemble. If it's the second situation, I can't help you there.
