20 Most Recent
Compaq S4 100 Flatbed Scanner Questions & Answers
Red images when I scan...
That means, your scanner lens are not reflecting images properly so
you need to clean ADF kits and Glasses of Lens.
i highly recommend not to mess up with your scanner if you are not aware of those all parts and if you are just open up scanner glass cover and clean those all ADF kits otherwise better getting help of a printer Tech.
Good luck
and rate all answers.
Apple v. PC
HP/Compaq does not offer MAC drivers for S4100 Scanner.
Power adaptor
If you can find an adapter with the same Connector, Polarity,Voltage. and the required Amperage or higher, it should work.
You might be able to find the exact part on Ebay or an online store.
Here are the part numbers depending on you location.
218864-001 Power module (USA, Canada)
218864-371 Power module (Asia/Pacific)
218864-A71 Power module (PRC)
218864-AB1 Power module (Taiwan)
218864-AC1 Power module (Hong Kong)
Scanner s4 100
dear all
please advise me where i can get driver cd for this scanner
Scanner?
None of the above.
Both the scanner and the printer connect to a computer.
If you care about technical language, the scanner and the printer are USB clients. The cannot communicate with each other. The need a host for that. A computer has USB host device built in.
Printer
Go to Control Panel look and see what printer or printers are connected to your PC.
Then I would try to reinstall my new printer.
