20 Most Recent Compaq Presario 4410US (470027-053) PC Desktop Questions & Answers
IS THAT A Relic CRT monitors/?? wow.
NOW THE FULL STORY. (GOT TIME NOW, IM IN MEX,GULF ON A BOAT,WITH SLOW WIFI OR NEAR DEAD.)
the PSU is dead if the power button acts dead
no fans right ? no sounds, the 2 or 3 fans do not spin and blow
1: bad PSU
2: or objects plugged into the mobo are shorted,
3: mobo dead (Motherboard)
do the jump test?
here
http://www.pcdied.com/power.html#Jumper
Compaq Presario... | Answered on Jan 27, 2018
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You are experiencing what referred to in the computer world as a dead computer system.
You either have a dead power supply or a dead computer mainboard or a dead Processor.
However it may also be a short circuit some where in your computer system.
However see my published guide entitled,
My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanks
damnor01
Compaq Presario... | Answered on Feb 16, 2011
remove the motherboard from Cabinet and check only M/B and SMPS see if restart ..? 2. Check any components it's burned.
Compaq Presario... | Answered on Feb 10, 2010
this happened to me alot when i would get a virus.......usually bad news.....i had to reinstall windows everytime. but first i would check to make sure the network drivers are the most recent versions.
Compaq Presario... | Answered on Oct 07, 2009
in command window try
ipconfig /release
then
ipconfig /renew
to pull a new ip
then try
ping www.google.com
to check if you can resolve hostnames
also try
ipconfig /flushdns
to clear old dns entries.
can also try disabling unused internet adapters, in case there's a conflict
In some instances your PC may not be properly recognizing one or more memory modules. Because you've recently installed new memory, check to be sure it's properly seated in its socket and the module is compatible with your system.
If the module is properly secured and appears to be compatible with your system, remove the RAM and try cleaning the pins using rubbing alcohol and a cotton swab. Clean each socket on the motherboard, as well with a soft, clean, dry paintbrush and then blow the remaining dust out.
If problems persist, try changing the order of your memory modules. DIMM sockets on the motherboard are labeled (DIMM0, DIMM1, etc). You should always start installing memory in the lowest numbered socket available. In many cases, the BIOS will probe the memory module in DIMM0 and address all memory according to the specifications of the module in DIMM0. If you've installed faster memory in DIMM0, the system may not be able to communicate with slower modules in other slots. Placing a slower module in DIMM0 may fix your problems; however, the faster modules will then, of course, run at a slower speed).
Hope this helps.
Compaq Presario... | Answered on Sep 10, 2009
Did they work before?
Compaq Presario... | Answered on May 11, 2009
Good luck with that. Why would you want a 23 year old CRT when there are Ultra HD flat widescreen monitors available. Even if you could find on in working order, it is likely to fail in the very near future.
Compaq Computers... | Answered on Apr 30, 2020
Try downloading VLC media player. Do a quick Google search for it.
VLC is a free media player and without additional downloads will play almost any format you can throw at it.
Compaq Computers... | Answered on Mar 24, 2020
Try installing VLC (VideoLAN- you can get it free by googling it) and using it to open the disk. Should work fine
Compaq Computers... | Answered on Mar 10, 2020
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Compaq Computers... | Answered on Jan 20, 2020
Start your web browser,
find options, open options.
Find and open search.
On this page you will see
"Use the address bar for search and navigation"
and
"Add search bar in toolbar"
which puts a separate window next to the address bar with search written in it..
Choose which one you want to use
Go down to one click search engines.
You will see a number of search engines in a box usually ticked.
I use a search engine called Duckduckgo because it does not keep any data on me...
under the search engines box there is a line in blue "Find more search engines".
Click on the blue line and you will see a list of different search engines, click on one and a new page will open up and you follow instructions to install the search engine.
In she search engine box, if you do not want use one of engines just un-tick it
Hope this helps
Regards
Geoff
Compaq Computers... | Answered on Jan 11, 2020
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered on Jan 06, 2020
Google
make model manual
They are all online. It _may_ be an eject button
Replace the CMOS (Complementary Metal-Oxide Semiconductor) battery to ... Turn off and unplug the netbook before replacing the battery. ... Press both orange eject buttons simultaneously, and use a spudger to pry off the back case. .... Tablet · Phone · Laptop · Repairable Products · E-waste · Recycling · Manufacturing ..
Compaq Computers... | Answered on Dec 26, 2019
Check this:
http://diy-ksoft.com/arduino/578-28-inch-tft-lcd-touch-screen-module-uno-expansion-board-for-arduino.html?search_query=LCD+arduino&results=114
There are a lot of touchscreens for arduino. Also if you want to keep it firmware compatible with what you have, you need to know the model and the interface type for it to get a new one that yill match yours.
Without further details is not possible to help you more....
Regards,
L. Coelho
Compaq Computers... | Answered on Dec 20, 2019
You stated an issue about playing/viewing AVI files on your computer?
I would suggest to go ahead and download an AVI file converter(w/c you can search via google or download via Filehippo.com)or get an AVI viewer/Player
(e.g. VLC etc./can also be searched/downloaded via gooogle.com or FileHippo.com)
Hope This Helps.
Thanks,
FixerDelta
Compaq Computers... | Answered on Nov 20, 2019
Compaq Presario 4410US (470027-053) PC Desktop Logo
Popular Tags
8 questions posted
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
front usb port not working
  • Computers & Internet
