WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the power lead from the power in put on the computer remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
i was unable to locate your spicific computer i hope this will guide you http://www.youtube.com/watch?v=qzFB-URV6EMReplacing a hard drive in a Compaq Presario SR5010NX PC
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
YouTube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html
Hope this helps.
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device hope this helps you
1 st of all scan ur pc for virus....if u get any virus properly nuterlize it ...i recoment avg 7.5 anti virus..
if it doesnot work ...then re install ur window..
i m sure ur problem wll be solved...
best regards & best of luck..
17 questions posted
3,409 Questions
2,234 Questions
1,799 Questions
796 Questions
724 Questions
