20 Most Recent Carrier Weathermaker 8000 Gas Furnace 125k Btu Questions & Answers
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Carrier... | Answered on Jan 15, 2018
Here is a link that might help. Even if it glows, it could still be bad, but it needs to prove air flow as well. Carrier Weathermaker 8000 Ignition Problem DoItYourself com Community...
Carrier... | Answered on Sep 20, 2017
These gas furnaces are very simple with few moving parts. Manufacturers added another moving part, and another way for unit to fail, by adding an electrical safety switch, which interrupts electrical command to unit to operate if the switch is in the open position such as when the lower panel is removed. But sometimes the lower panel, even when in place, may not depress switch enough to keep it closed. To see if an open switch is your issue, first verify that key unit components are working -- themostat works properly, gas supply to unit, electricity to unit, gas valve opens, flame ignitor comes on, fan comes on. If yes to all, check to see if the lower panel electrical safety switch works, and is positioned correctly. If the switch, or panel, is out of place or removed, the switch should remain in open position, and the unit will not run. If panel is not pressing against switch sufficiently, switch may not close when panel is in place. Given the coefficient of expansion of the steel plate the panel is made of, the panel may cool and contract enough to hold the switch closed when the unit first turns on. As the inside of the furnace heats up, the panel and frame of the unit expand as the metal parts heat up, and as the panel moves away from the switch due to expansion, the switch opens and the unit cuts off even though the lower panel is in place. This may take several minutes, or longer. If the panel remains far enough away from the switch after the switch opens and unit stops operating, the switch could remain open and prevent power flow/themostat signal prompts from activating the unit even when the unit frame and panels cool and contract. To check to see if an open switch may be your problem, turn off power to unit, remove top panel, remove bottom panel, check switch to see that it physically opens and closes, replace lower panel, replace top panel, turn power back on. Do this repositioning lower panel exactly as you was before you removed it, without pushing the lower panel in toward switch. If unit does not activate, or stops working after several minutes while thermostat is set to command unit to heat, an open switch may be the issue. To test for this, apply light physical pressure to lower panel, toward unit, over switch location. Cycle unit power switch off, then on. If unit activates and runs normally, insufficient panel pressure against switch, causing an open switch, may be source of problem. Possible fixes include putting lower panel back into place repositioned so that it presses more against switch, or taping a very thin shim (such as a square of cardboard cut from a cereal box, but must be done competently as tape and cardboard fluttering loose inside the blower compartment may lead to fan fouling issues) to the inside of the panel so that it depresses the switch more, or bending the panel so that it protrudes slightly toward switch (not recommended as once bent, panel is hard to get back into place properly, and bending may cause other issues), or carefully repositioning or nudging the switch toward panel (its fasteners may have come loose inside the unit frame, or switch may have vibrated out of place over time). If unit still will not cycle on, use a multimeter to see if the switch, when closed, allows current through the line (a continuity test). This might detect a bad switch. If the switch tests good, do a continuity test when the panel is in place, using alligator clip extension wires to test to see if the switch closes when panel is in place. Do this this test with main unit power turned off. If switch tests good when panel is removed while you are physically holding the switch closed, but tests open when panel is in place, manipulate/reposition/shim the lower panel as noted above.
Carrier... | Answered on Mar 10, 2015
Look on the motors. If there is a rubber cap (sometimes metal) on each end of the motor then a few drops of oil should be put in once a year.
Carrier... | Answered on Nov 06, 2014
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Carrier... | Answered on Oct 27, 2014
Restarting after removing the power is how the equipment is designed to operate because removing power temporarily clears the fault code. Not starting could be caused by a number of built in safety devices such as roll out switches or partially blocked flue pipe. I've seen them with bird's nest in it. This should be looked at by a trained professional.
Carrier... | Answered on Jul 11, 2014
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Carrier... | Answered on Jan 29, 2014
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Hi Shelley, I'm sorry this is late, I have a back problem and often times can not sit at the computer. Removing the front cover causes a "HARD" reset to the furnace. That means, it breaks the line or supply voltage to the furnace. The main reason for requiring a hard reset is a failure to fire up correctly. The flame on the sensor can vary between lighting the pilot and the main burner ignition. The flame can be pulled away from the sensor just long enough to cause this type of failure before the main flame is sensed. The furnace will shut down thinking it is feeding in raw gas with no pilot present to ignite it. All of this happens in just a couple seconds. If there is a small window in the burner cover, you can watch it fire by holding the switch in by hand. If there is not an inspection window with a sealed combustion chamber, it would be best to call a good tech. as it is dangerous with such a short period to ignite while all that gas is flooding the combustion chamber. Without knowing exactly how to do this, it could explode. BE CAREFUL !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Carrier... | Answered on Dec 27, 2013
Carrier Weathermaker 8000 Gas Furnace 125k Btu Logo
55 questions posted
Top Carrier Air Tools & Compressors Experts
Tom Chichester
J Rosado
Marvin
Marvin
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Air Tools & Compressors
Most Popular Question
furnace will not start s own
  • Air Tools & Compressors
