20 Most Recent Compaq Presario SR1050NX (DW257A) PC Desktop Questions & Answers
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Compaq Presario... | Answered on Jul 26, 2014
You're typing like you have been working tirelessly on the problem.
In fact there is no user name, lol!
Okay.....relax...........just ease back, and put your hands behind your head, and close your eyes.............think about clouds floating across in the sky.
Better?
Alright.
Your Power Supply is bad. Weak voltage power rail.
Replace it.
Don't think so? Cool.
That's what I'm here for. To teach.
Have a multimeter?
A) If ALL of the LED's were on they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
(Older Intel Pentium I, II, and III, uses less than 51 Watts. Some older AMD's do also)
Primer:
You press the Power On button. The plastic assembly of the Power On button in turn presses against a Power On switch,
http://www.directron.com/atxswitch.html
The Power On switch is a Momentary Contact Switch.
When briefly closed the Power On switch completes a circuit.
The Soft Power On circuit.
When the Power Supply is plugged into power, there is a constant 5 Volts (DC) present.
The 5 Volt Standby power.
Pressing the Power On button redirects the 5 Volt Standby power, in the Power Supply. This 'excites' the Power Supply, and turns it on.
(Soft Power On circuit)
The first chipset (I.C.) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(WinXP and Win7 are two examples of an O/S)
Primer over.
1) http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&lang=en&lc=en&product=405454&
2) http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00595250&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=405454
FOLLOW Anti-Static Precautions
2a) http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3433073&prodTypeId=12454&objectID=c01358034
(Yes, I know. Slightly different computer case. Principles still apply)
3) Don't think you will be hearing any BIOS Beep Codes, because there isn't enough power, lol!
For additional questions please post in a Comment.
Regards,
joecoolvette
(If Power Supply power were dynamite, your Power Supply wouldn't have enough power to bl-ow it's nose)
Compaq Presario... | Answered on Aug 28, 2012
Presarios normally let you access BIOS setup by pressing F10 as soon as the Compaq logo pops up on the screen when starting it. I've read that F1 is the key on some pre-2006 Presarios. Pressing the F10 key multiple times immediately after starting can be helpful.
Compaq Presario... | Answered on Aug 21, 2011
Try admin or just hit enter. If not remove the battery from the mother board for 5 minutes and see whether it helps. If you haven't entered a password on BIOS there shouldn't be any problem. Also try deleting if you have any other users accounts on the system.
Good Luck!
Compaq Presario... | Answered on Jun 09, 2011
The BIOS battery in most desktop motherboards is a coin size lithium battery approx. 20mm in diameter. The most common type used is a CR2030 3volt lithium battery.
To release the battery, press the metal clip to the side and the battery should pop up.
Compaq Presario... | Answered on Nov 26, 2010
Yes a common situation I have see this very often, the trick is to find out the faulty component before purchasing replacement parts. Go through my guide, it deals with this matter and will get your computer going! It is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing!
damnor01
Compaq Presario... | Answered on Nov 23, 2010
I have the same SR1050NX compaq computer with the same startup problem. I suspect this from a code seeded in the system, so performed the system recovery for several times. The problem gradually came back, automatic shutting down with loger interval. I thought the bug is in the recovery system. But the floppy drive in the cmos is disabled without choice to be activated. So, I couldn't perform FDISK at DOS mode. For this computer, I wonder anyone knows how to activate the drive for boot order besides through the setup window.
Thanks very much.
Josh
Compaq Presario... | Answered on Nov 22, 2010
115 Volts
Compaq Presario... | Answered on Oct 25, 2010
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
http://en.wikipedia.org/wiki/Socket_A
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Compaq Presario... | Answered on Oct 13, 2010
Hi, the green light I believe is just your networking socket. The fact nothing happens when you try turning on your PC could be serious. You will to take your PC in for repair, as this is not something I can diagnose without seeing the PC. Sorry this is not a straight forward answere.
Compaq Presario... | Answered on Jul 22, 2010
This usually means that there is a serious problem that should be looked at closely by a technician. For example, this could be related to a bad power supply, a faulty or dislodged processor, or even a motherboard failure. I could suggest checking these areas, but it is best left to a trained technician.
Compaq Presario... | Answered on Mar 13, 2010
go in control panel,sounds,startup sounds and disable all
Compaq Presario... | Answered on Feb 11, 2010
A few thing can be wrong.
  • Wrong speed memory - Make sure it is both xxxGHZ, same as your old memory (Take the old memory to the computer store)
  • Memory limit with each slot (Max memory divided by # slots)
  • Overall memory limit (visit the mfg spedific model's page)
  • Incompatable/Bad memory
  • Mix your old and new memory (1 old / 1 new) If the new is incompatable the old (in slot1) should work and an odd amount of ram displays
Compaq Presario... | Answered on Jan 18, 2010
u need to download new version of bios
Compaq Presario... | Answered on Oct 23, 2009
Recover CD can be purchased from Compaq. Contact them and provide details of the model number details etc.
Compaq Presario... | Answered on Jul 27, 2009
why not go to the compaq website and put in the name of your machine? they will direct you to the appropriate drivers for your whole system and you can save them on your hard disk in a location you pick, then you can upgrade anytime.
Compaq Presario... | Answered on Jun 26, 2009
Try "Crazy Glue" to glue the fan in place or buy a new fan and install it.
Compaq Presario... | Answered on Jun 23, 2009
Look at the back of the computer.Take off the side door, it will be the one with screw in the middle of the door. After you remove the screw, take off the door and then where the front panel is you'll see some tabs that are exposed, go ahead and push on the tabs, there will be a a few on each side. Once enough of them are pushed in, you should be able to remove the front panel. At this point the floppy drive will be exposed and you can remove the broken door with the screw. Then once you do this, you can put the front panel back on and you should be able to run the floppy drive like normal.
Compaq Presario... | Answered on Jun 07, 2009
go to 'support' at www.hp.com and look for dirvers for your model. There should be a driver for the 10/100 tbase ethernet device. Download and install it and reboot. Should fix the problem if the ethernet adapter is working.
Compaq Presario... | Answered on Mar 06, 2009
Processor and ddr2 work fine as it comes to fan you have to know what kind of fan it uses 80 mm or 120 mm.
Compaq Presario... | Answered on Feb 25, 2009
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
Popular Tags
38 questions posted
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
best upgrade cpu compaq presario
  • Computers & Internet
