20 Most Recent Compaq Presario SR1010NX (DW254A#ABA) PC Desktop Questions & Answers
PresarioA900 where is the web cam
being a desktop you will need to connect a portable webcam depending on your operating system it will differ click start control panel view devices and printers you should see your webcamclick start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X right click to reinstall drivers or update driver W7 click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed right click to reinstall drivers or update driver hope this helps
4/22/2012 10:21:53 PM • Compaq Presario... • Answered on Apr 22, 2012
One of my fans are broken and my internet running
check the lead/s that attach to the fan make sure the connection is good and the lead/s are not faulty. you might have to replace the fan if its bad/faulty
as for the slow internet you might have a virus slowing it down or another program accessing it
scroll to the bottom toolbar (bottom of screen) right click you will select task manager, applications and processes you will see whats running on your computer also users you will see who is using your computer hope this helps
1/7/2011 6:34:53 AM • Compaq Presario... • Answered on Jan 07, 2011
Cd, player does, not work i think i need to reload
Here is the page with all of the official drivers for that particular computer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=403786#N482
Click on the Driver - Audio (1) section and download that driver.
However, those drivers listed are for the hardware and operating system that comes with a Compaq Presario SR1010NX, so if you upgraded your hardware, or changed your operating system then do not download the driver since it will not work.
If you did change some hardware, or operating system, comment back and let us know. If you run a pc audit program such as Sandra Lite http://www.filehippo.com/download_sandra_lite/ you can find out your exact motherboard or audio card which would be a great help in finding the right driver for you.
If a driver upgrade does not fix the problem, comment back and let us know.
Hope this helps!
12/19/2010 6:24:53 PM • Compaq Presario... • Answered on Dec 19, 2010
The light on my mouse computer is blinking
did you try to shut down completely the computer? please press on the power button until no sound is heard and then turn on the computer. Also, please make sure that the screen is connected properly to the PC
10/4/2010 4:25:29 PM • Compaq Presario... • Answered on Oct 04, 2010
Computer asks for recovery disk
recovery disk for the model you're looking for is already installed within the hard drive, you can burn the disks out straight from the hard drive. the catch is, you can only do it once. so if you've already burned the recovery disks to CDs (or worse, if this computer belonged to someone else) you won't have access to the recovery disks anymore...
8/31/2010 9:39:48 PM • Compaq Presario... • Answered on Aug 31, 2010
I have a presario sr1010nx. i loaded a plain
need some confirmation: you tried to recover the windows with its recovery option but the windows wont load from the recovery. is this right? may i know if there is an error? if there is please send to me the error to my email: [email protected] please do introduce yourself and the topic we discussed. thanks,
5/18/2010 6:06:45 AM • Compaq Presario... • Answered on May 18, 2010
IT BECAME DUAL BOOT.. FORMAT C: DRIVE AND RE INSTALL OS PLAIN VERSION
3/29/2010 1:29:02 AM • Compaq Presario... • Answered on Mar 29, 2010
Windows starts loading then screen goes
Make sure that monitor cable is secure on back of PC and Monitor. Also ensure you have latest Graphics Card drivers.
1/12/2010 9:36:47 PM • Compaq Presario... • Answered on Jan 12, 2010
Configuration problems after system restore
You need to reconfig the system
12/13/2009 7:18:20 PM • Compaq Presario... • Answered on Dec 13, 2009
Trying to hook up harmon/kardon speakers to a new
Can't you connect them to the tower?
7/13/2009 5:46:49 AM • Compaq Presario... • Answered on Jul 13, 2009
Connected pc to logik 32in lcd tv, getting picture
Need clarification. Do you have speakers hooked up to your computer? Or did you just plug in a VGA cable from your computer to the TV? The sound can't magically go from your computer to the TV, because VGA cables don't transmit sound. So if you are indeed using speakers, which I doubt, it's a computer problem.
Basically, describe exactly what components you have and how they are hooked up.
6/27/2009 7:56:26 PM • Compaq Presario... • Answered on Jun 27, 2009
Tv as monitor
You may have to find the driver for this monitor before connecting the new monitor up. Go to the manufacture of the monitor and search in the support area for downloads and drivers. Load the driver then connect your new monitor up and see if it works. If not, then use a good monitor to power up first. Then, with computer on, put new monitor on and see if it will locate a driver.
6/24/2009 6:04:48 AM • Compaq Presario... • Answered on Jun 24, 2009
My Compaq Presario SR1010NX is freaking out. The
If you want to test the monitor. plug it into another computer. Most likely its the video card on the computer and not the CPU. CPU's dont give you lettering streaks. Also try plugging your computer into a different monitor. If it is still streaking then it definitely is the video card and in that case just replace the video card.
3/23/2009 6:06:51 PM • Compaq Presario... • Answered on Mar 23, 2009
My Compaq presario sr1313cl desktop pc, is not working a Capacitor is bad!
Replace the capacitor.
9/25/2022 4:31:03 PM • Compaq Computers... • Answered 14 hours ago
3answers
I have a compaq cq5110y computer. When I push the power button nothing happens. It doesn't turn on, no fan or lights come on either. The only light that is on is on the back of the computer and it's
It might be a connector cable between the mother board and the power supply has worked loose when the machine was moved. That blinking light appears to be on the power supply. While there might be other causes, I suspect the power supply needs to be replaced. You could take up considerable time and try to reseat everything and check all the connections and even put new thermal paste between the CPU and heatsink, but in the end, I suspect putting in a new (or used of the same type) power supply will be the fix. If the power supply has failed before damaging anything, that at least would be good news.
8/26/2022 8:55:03 AM • Compaq Computers... • Answered on Aug 26, 2022
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch. XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020??? gee google that. 2001 to 2007 was XP rein , vista 2007 I bet there are 1millons of web site still with XP usage .(old topics) google them. but Microsoft purged theirs. it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen.. worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC) to use any relic PCs run LINUX> not XP
7/27/2022 4:10:03 PM • Compaq Computers... • Answered on Jul 27, 2022
My Compaq Presario Laptop won't open certain sites because they are not "secure" eg. Quora, BBC Weather, sundry health sites, etc.
Question edited for clarity, and Maker name. Question moved from BBC Computers. BBC Weather and Quora and both secure and have an http*S* security certificate. My guess is that you have a third party security app, or worse, two of them, not understanding status or fighting with each other.
7/12/2022 10:03:51 PM • Compaq Computers... • Answered on Jul 12, 2022
Compaq Presario SR1010NX (DW254A#ABA) PC Desktop Logo
22 questions posted
Top Compaq Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
windows starts loading screen goes
  • Computers & Internet
