20 Most Recent Compaq Inkjet Ij300 Printer Questions & Answers
kaju, pls download the driver from this linkhttp://members.driverguide.com/driver/detail.php?driverid=77667&action=summary
Compaq Inkjet... | Answered on Sep 01, 2014
The first 2 things I would do are check that you are using genuine Canon cartridges and run a head clean on the printer.
Head cleaning options are usually available under printing preferences for the device.
Compaq Inkjet... | Answered on Mar 21, 2014
Follow the instructions. If you lost them you can get them from Compaq's website.
Compaq Inkjet... | Answered on Jun 16, 2011
I presume you mean install and not connect,.... Go to Compaq and look under downloads and support, and get new install program for your printer and OS.
Compaq Inkjet... | Answered on Mar 06, 2011
yes, can be.:D just follow these steps:
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Compaq Inkjet... | Answered on Dec 06, 2010
You can download the printer driver for this from this link, just click HERE and continue with the download.
Compaq Inkjet... | Answered on Nov 11, 2010
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Compaq Inkjet... | Answered on Mar 14, 2010
Examine the printer and youwill see a depression that is designed justfor on finger.
Tug on it an the door will open and the cartridges will be exposed.
just press on th efront of each one at a time and each will fall forward.
position th enew one in a similar fasion and push itin place.
Then close the door and press enter.
you should be good to go.
Compaq Inkjet... | Answered on Jan 16, 2010
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Compaq Inkjet... | Answered on Dec 14, 2009
try printing a test page from the properties menu of the printer and see what happens.If it's alright thenit;s what you printed that cause the reduction
Compaq Inkjet... | Answered on Oct 07, 2009
You need to reinstall the software after you completely uninstall the first one first and reboot your computer then run software cleaning function for the heads and run the alignment, make sure that you move all the stickers from the cartridges and the vent hole is clear...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Compaq Inkjet... | Answered on Sep 20, 2009
I found this solution on another website, I suggest you give it a try.
Everything works fine since I installed Vista except for my printer a Compaq IJ300 which is a Lexmark Z11 in disguise. I installed the driver for the regular Z11 through the "Add Printer " but had problems.
Went to Lexmark site - downloaded drivers for Z11 Series ColorFine- working perfectly. So far I have no other problems with vista.
Compaq Inkjet... | Answered on Aug 26, 2009
your printer catridge has been faulty. pls reolace it.
Compaq Inkjet... | Answered on Aug 20, 2009
cartridge setting was on color changed that to black and problem was fixed
Compaq Inkjet... | Answered on Feb 16, 2009
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Compaq Inkjet Ij300 Printer Logo
Popular Tags
34 questions posted
Top Compaq Office Equipment & Supplies Experts
efs_perpends
efs_perpends
Jax Planet
Jax Planet
Mike
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Office Equipment & Supplies
Most Popular Question
connect
  • Office Equipment & Supplies
