20 Most Recent
Baumatic B187 Stainless Steel Electric Single Oven Questions & Answers
When i turn electric oven on the house fuses blow no fan no heat
If this is a new oven, look at the plate on the oven or in the user manuel. It should show the input amperage. Then check the amperage number on the fuse. If the fuse number is lower, that is the problem. To fix it will not be easy. The oven circut needs to be rewired with heavyer gage wire and a larger capicity fuse. This could get expensive.If this problem is on an existing oven, chances are there is a wiring or switch problem. If you are not familier with electricity here is my recommendation.STOP! and call an electrition. the chances are high that if you try to fix this on your own you may be electrocuted or you may burn your house down.
How to fit the splashback
Hi Do you mean the screws don't match up with the holes ? I find this all the time I drill new holes to make it fit correctly. One thing you should know is stainless is very hard to drill so go to the hardware store and get a bit for stainless and also get it just a little smaller then the screws, if you bring the screws with you they will help you get the correct bit , rate this call thanks Frank
