20 Most Recent
Maclaren Global Buggy - Bluebell Umbrella Stroller Questions & Answers
What year is this stroller from? do they still
This model is about three years old and is a very good stroller. This was initially designed to work with the Britax Rock-a-Tot (especially adapted to fit onto the stroller with adapters). This model lasted only one season, was available in Bluebell and Carbon colours ( I think!) and is robust and will more than likely, be able to go through a few children.
My opinion is that if you don't plan to use this with a carseat as a travel system, then go ahead and purchase the product. Check that the weight and size of this is suitable for your needs, and that this will fit into your car boot first.
I hope this helps.
Front wheels of maclaren quest 2016/2017 model are strugling to get into position they are being pushed.
It sounds like there may be a problem with the front wheel assembly on your Maclaren Quest 2016/2017 model stroller. You may want to try removing the wheels and reattaching them to make sure they are properly seated and aligned. If this does not solve the problem, there may be an issue with the wheel locking mechanism or other parts of the front wheel assembly. It may be best to contact Maclaren customer service for assistance with troubleshooting and potential repair options.
As for the safety straps, it's possible that they may need to be adjusted or reattached properly to prevent them from coming apart. The instruction manual for your stroller should have information on how to properly adjust and attach the straps. If you don't have the manual, you can find it online on the Maclaren website or by contacting customer service.
Stroller snap open
Hi, It sounds me to that you need a replacement chassis which I can get hold of very easily for you. Let me know if you would like me to do this for you. Thank you
